0 Members and 1 Guest are viewing this topic. Read 19927 times.
Seems like Mike went above and beyond the build specsto ensure a non-resonant cabinet. Wonder what Mike wouldestimate the total assembly time, given the extra cuts for additional bracing?I can appreciate the quest to minimize cabinet resonance, having justcompleted a Rythmik/GR sub build using Danny's sealed sandbox design.Also curious if any No-Rez or Black Hole was used for further resonance damping.Thanks to Mike for a great article.
Great review Mike! Very informative.For those needing a sub system for the Abbey (or other main speakers): IMO Earl's mulitple sub advice is one of the most significant & cost-effective breakthroughs in audio. Three subs are the minimum for the mode-null effect (its mode-nulling effect can not be overstated or overemphasized). Powered subs (Polk IIRC) were mentioned in one of Earl's www.DIYaudio.com threads about six weeks ago; they had an original MSRP of $250 & were being blown out somewhere for $99. Earl posted that the subs mentioned would work fine as long as the ports were plugged & the LP xo poles staggered. (I'm pretty sure it would best to leave one port open, partly seal one port & seal the last port, thus staggering the respective Qs. Other siting & polarity points must be followed including one sub being sited above ear level but believe me it's worth the effort; the worse your modes the better the effect.)
Mike,Some things you can try to extend the tweeter response:1. Remove binding posts and hardwire....always more open and extended and dynamic sound.
2. Try your Behringer digital x-over......that way there are no caps, resistors and inductors in the signal path and you can play with equalization to bring out more top octave. You might be able to cross over even lower....say 700hz....with the steeper xover slopes.3. Try a better compression driver. A friend A/Bed the B&C with the Beyma and preferred the Beyma for top end response and clarity.....the Beyma is the one that Duke uses....more money....of course.4. Remove the foam and try some small pieces of felt on the inside of the waveguide........or buy some extra foam and make a hole in the middle so some sound comes directly at you without going through the foam but having the rest foamed will reduce bouncing waves in the guide. You can try just felting the outside lip of the waveguide as well.
Mike, I have experienced the difference between two subs & three ala Geddes; the difference can not be overstated in a room like mine w/ bad modal problems & non-flex concrete floor & front wall. I imagine the less bad the modal problems the less great is the advantage.
My sub drivers arrived on Monday and the amps yesterday, so I know what my next project is.
