Ref 9 V1 blue led
0 Members and 1 Guest are viewing this topic. Read 1363 times.
ddiego09
Ref 9 V1 blue led
« on: 4 Mar 2009, 05:19 am »
One of my Ref 9 after half an hour will turn off the blue led, any idea why?
Next day turn the amp on the led is on and later on same story...
stingfan
Re: Ref 9 V1 blue led
« Reply #1 on: 6 Mar 2009, 05:44 am »
Same here for my P-8.  My input source 1 LED light goes out every other day, then back on.  It is my most used source, and thus on the most. Most likely Nuforce have some not-so-long life LED components, or low mean-time-between-failure rating, MTBF.
Only owned my P-8 for 2 years too. Minor bummer.
rustydoglim
    • www.nuprimeaudio.com
« Reply #2 on: 7 Mar 2009, 03:04 am »
Contact us to get a new LED replacement free of charge. I think you can replace it without soldering. The LED was an issue with version 1 amp but not for V2 amp.
ddiego09
« Reply #3 on: 9 Mar 2009, 04:52 pm »
thanks !
