Need a component video switcher
0 Members and 1 Guest are viewing this topic. Read 1949 times.
BobC
« on: 4 Mar 2009, 02:06 am »
Looking for a simple, cheap (<$20) but good quality 2 way (1 in, 2 out) component video switcher.  Simple manual A - B switch without a remote.
Can anyone recommend one?
Thanks, Bob   :D
Mariusz
Re: Need a component video switcher
« Reply #1 on: 4 Mar 2009, 02:17 am »
Thanks, Bob   :D
If you have Circuit City in your area - hurry.
Since they are closing down for good, there are a lots of good deals to make.
They sell everything.....including switchers, cables used for demo.... even Samsung hard drive player to demo HDTV.  :drool: :drool: :drool:
Cheers
Mariusz :thumb:
BobC
« Reply #2 on: 4 Mar 2009, 07:28 pm »
Sorry, I meant 2 in and 1 out.
Should mention this is for HDTV so want a good video quality switch....but don't want to spend a lot.  Switch is a temporary fix until I get a new HT receiver...so if the cost is much more than $20 or $30 then would want to put that maney into a receiver.
Also, I did call Circuit City and they're picked over.
Thanks, Bob
bpape
    • Sensible Sound Solutions
« Reply #3 on: 4 Mar 2009, 08:13 pm »
I'd say just wait.  Getting a DECENT switcher for $20-$30 isn't likely.
Bryan
satfrat
« Reply #4 on: 5 Mar 2009, 01:26 am »
Bryan
I agree with Bryan, if you want to retain a high quality High definition picture, you will want to look for a switcher that will pass a wideband signal w/o any signal loss. As you mentioned in a PM Bob, you might be better off simply replacing your receiver for one with multiple component video inputs. I would highly recommend looking for a used receiver on either Ebay or Audiogon. Look for a receiver that's only a couple years old at the most, there's lots of good deals available in todays market if you shop wisely and do your component homework. :thumb:
Robin
BobC
« Reply #5 on: 5 Mar 2009, 03:31 am »
Thanks guys   :thumb:  Will probably just continue to suffer the inconvenience of swapping cables for a little while and pick up a new receiver.
satfrat
« Reply #6 on: 5 Mar 2009, 03:37 am »
Don't feel bad Bob, I'm doing the same thing at my processor with my Crystal Cable digtal cable from my Empirical Off-Ramp 3 USB transport for music to my M-Audio Rev 7 sound card for DVD movies. But then again, it's my 1 cable to your 3 cables. :lol:
Robin
thanksday
« Reply #7 on: 26 Mar 2009, 02:17 am »
i use Nidesoft which work very good for me
but it's $29
WGH
« Reply #8 on: 26 Mar 2009, 05:49 am »
Monoprice has one for $22.88, it has a ton of rave reviews.
http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10112&cs_id=1011201&p_id=3027&seq=1&format=2
I use a 4 port component switcher from Monoprice (not this model) and it works just fine with my standard def projector.
All their stuff seems to be high quality.
W.
