Pioneer Elite VSX-81TXV Receiver, 110W x 7, HMDI (sold)
0 Members and 1 Guest are viewing this topic. Read 2289 times.
mikeg1
Original owner with low usage and in excellent condition.  See audiogon feedback under mikeg.  Was $1000 new and purchased from authorized dealer (Audiomart).  Asking $399 plus shipping.  Upgrading to $2200 Pioneer Elite model.  I have the original box, manual, and remote.  Was place in my rack and never moved.
More connectivity, more control, more ways to enjoy your high-definition entertainment. Put this extraordinary Elite® A/V receiver at the center of your home entertainment system, and take your experience to a whole new level. Connect an array of audio and video sources via six digital inputs, including two HDMI inputs compatible with the latest — and still to come — high-res 1080p sources like Blu-Ray Disc® players. With simplified one-cable connection to your HDTV, HDMI protects the digital purity of the signal for high-quality audio and video with no loss, and no mess of wires. TBC Digital Video Conversion takes signals from older video sources (connected with composite, S-Video, or component video), and can output them via HDMI so one wire is all that's needed from the receiver to the TV or Monitor.
Dolby(R) Digital 5.1
Dolby(R) Digital EX
DTS(R) 5.1
DTS-ES Discrete 6.1
DTS 96/24
DTS NEO: 6
Pro-Logic IIx
Windows Media(R) Audio 9 - Professional
THX Select2
Sound Retriever
Virtual Surround Back
Midnight Listening
Dialog Enhancement
Hi-Bit Sampling
Loudness
Advanced MCACC
Speaker Identification
Speaker Size
Speaker Level
Speaker Distance
Phase Control
Standing Wave Control
X-Curve Compensation
Advanced MCACC 3-D Display via PC
XM (R)Ready
XM HD with Neural Surround
Video Conversion - HDMI
Video Conversion - Component
Video Conversion - S-Video
Headphone Output
Front A/V Inputs
RS-232C
AC Outlet
System Remote Plus (SR+) Port
IR In/Out
Banana Speaker Terminals
3-D Space Frame Design
Direct Construction
Direct Construction
Pre-programmed
Learning
IR Macro Commands
Dot Matrix Display
Specifications:
Power Amplifier Design Direct Energy
Surround Power 110 Watts x 7 (20Hz - 20 kHz, 8 ohms, .09% THD FTC)
Stereo Power 110 Watts x 2 (20Hz - 20kHz, 8 ohms, .09% THD FTC)
Digital Engine Sharc EX + 48-Bit Freescale DSP
Advanced Surround Modes 12
Acoustic Equalization 9 Band Adustable
Analog to Digital Conversion 96 Khz / 24-Bit
Digital Analog Conversion (DAC) 192 kHz / 24-Bit
Made for iPOD (R) Yes - Audio. Cable included
Analog Audio Inputs 3 (includes tuner)
Analog Audio Outputs 1
Digital Inputs 6
Optical In 4 (includes front)
Coaxial In 2
Optical Digital Outputs 1
Multi-Channel Input 8 Channel
Audio Pre-Output 8 Channel
Composite Video Input 5
Composite Video Output 1
S-Video Input 5 (includes front)
S-Video Outputs 1
Component Video Input 3
Component Video Outputs 1
Monitor Outputs 4 - HDMI, Component, S-Video, Composite
Video Signal Select Yes
Component Video Frequency Response 100 MHz
HDMITM Inputs 2
HDMI Output 1
Multi-Room and Source Output 2 Zone - Main, 1 A/V
12 Volt Trigger Yes
Speaker B B Speaker or Surround Back Speaker
Assignable Surround Back Speaker 4 Mode - Normal, 2nd Zone, Front Bi-Amp, MR&MS
On-Screen Display Yes
Remote Type LCD Preset / Learning Remote with preset multi-operation
Front Panel Alumin
Dimensions (inches) 16.54 x 6.81 x 18.35 (WxHxD)
Weight 33.8 lbs.
« Last Edit: 16 Mar 2009, 02:00 am by mikeg1 »
