0 Members and 1 Guest are viewing this topic. Read 5509 times.
more info herehttp://www.metal-wear.com/Stereo.html
Quote from: jenhwa on 6 Mar 2009, 06:50 ammore info herehttp://www.metal-wear.com/Stereo.htmlall my tubes is cryo you have right the sound after cryo is amaizing but i scare put the transformers TVC because have paper between cable
Frankly I would really have to wonder if cryoing would have any negative effect on paper,,,, it's rubber and adhesives you need to worry about. It wouldn't hurt to ask Cryoparts or Cryogenics International for an opinion.
Quote from: satfrat on 7 Mar 2009, 05:42 pmFrankly I would really have to wonder if cryoing would have any negative effect on paper,,,, it's rubber and adhesives you need to worry about. It wouldn't hurt to ask Cryoparts or Cryogenics International for an opinion. Post some pics and I'll opine on how the stuff will come through. Nick from Promethius would be a good resource to ask as well.Peace, Lee
well then let me buy a lottery ticket,and if i strike it, i will commission a tvc with Teflon instead of paper,and house it in custom solid aluminium chassisand then cryo treat it ......dreaming ......drooling......
Quote from: cryoparts on 7 Mar 2009, 07:32 pmQuote from: satfrat on 7 Mar 2009, 05:42 pmFrankly I would really have to wonder if cryoing would have any negative effect on paper,,,, it's rubber and adhesives you need to worry about. It wouldn't hurt to ask Cryoparts or Cryogenics International for an opinion. Post some pics and I'll opine on how the stuff will come through. Nick from Promethius would be a good resource to ask as well.Peace, LeeRobin directed me to some pics of the component. I think the tranny would come through fine, however, I don't think the wood case would make it, the adhesive would probably fail and the wood might crack.Peace, Lee
Lee i think the best thing is to have just the transformer and if possible the switches cryoed. i beleive this would increase the performance of the entire unitthanksNicholas
Quote from: jenhwa on 7 Mar 2009, 06:08 amwell then let me buy a lottery ticket,and if i strike it, i will commission a tvc with Teflon instead of paper,and house it in custom solid aluminium chassisand then cryo treat it ......dreaming ......drooling......Doing the tvc in teflon is not that expansive actually. Around USD30-60 i think, may be less just top of the head. custom solid aluminium chassis fully mill would be nicerMill the entire chasis out of solid aluminium even better solid copper would be bestthen cryo
