FS: Monster HTS-3500 MKII and OneAC Transformers
0 Members and 1 Guest are viewing this topic. Read 1090 times.
gitarretyp
« on: 2 Mar 2009, 03:13 am »
For sale is a Monster HTS-3500 MKII Power Center and two OneAC isolation transformer units, CP1105 and CP1103. All units are modified. Photos are posted in my gallery.
First the Monster: I installed an IEC power connector, replaced two of the outlets with Hubbell hospital grade and one with a Pass and Seymour (leaving two stock outlets), and upgraded the input and output wiring with higher gauge wire. I bought this unit as b-stock, cosmetically damaged during its original shipment. One front corner is dinged, there's a dent on one side, and the ground lug on the back is a little bent --see photos in gallery. Also, the timed outlet relay failed and is in the stuck on position --this never bothered me as I always left them on. The two switched outlets still function correctly.
Asking $80 OBO.
Second are the OneAC units: The CP1105 is rated for 4.6A output, has rubber feet, installed IEC,  two Cooper hospital grade outlets, and upgraded wiring. The CP1103 is rated for 3A output, has mounting bracket rather than feet, installed IEC, two Pass and Seymour (i think) outlets, and upgraded wiring. Both units are a little on the rough side cosmetically, but they're kind of ugly in the first place. Both units hum/buzz to some degree.
Asking $20 OBO for the CP1105 and $15 OBO for the CP1103.
« Last Edit: 8 Mar 2009, 06:05 pm by gitarretyp »
gitarretyp
Re: FS: Monster HTS-3500 MKII and OneAC Transformers
« Reply #1 on: 8 Mar 2009, 06:05 pm »
Bump - Reduced
