PLESE HELP! Which is the best sounding amp? the 8.5v2 or the Ref9 (v1)
0 Members and 1 Guest are viewing this topic. Read 1255 times.
jwo
I'm happy if someone could give me a hint what to choose...
I just got hold of a little bit of money and Im thinking of an uppgrade..
Which is the best sounding amp? Ref 8.5v2 or Ref 9v1?
Today I own P8 pre and amp: ref 8.01b from the year 2005.
Is it worth the uppgrade? Will there be a difference compared to my ref 8.01bs?
WHICH ONES OF THEESE TWO AMPS ARE THE BEST SOUNDING ONES??????
i need to decide within a couple of hours :D
Shall I do it?
Will it be a big difference?
Please Help!
« Last Edit: 1 Mar 2009, 09:40 pm by jwo »
rustydoglim
    • www.nuprimeaudio.com
You can also upgrade from Ref 8b to Ref 8V2 (we just replace the amp and power supply).
With Nuforce, you have many options :)
Ref 8V2 is nearly identical to Ref 8.5V2 but will save you money.
V2 is much better than V1 so always choose V2 over V1.
