Possible to buy from northAmerica and use it in Europe? 110volts/220volts?
0 Members and 1 Guest are viewing this topic. Read 1480 times.
jwo
Is it possible to use a north american nuforce amp in europe without voltage convertion?
on the back of the units , it says 110-220volts
Does the amp adjust itself or do I need some kind of converter?
Cheers! Jon, sweden
jwo
Ok. Iknow now its possible.
Frihed90
It will fit nicely in your carry-on and save you 25%+ duty + shipping.  There are many US mfrs that will sell a 220-230-or 240 V piece of equipment to a person in the US, and then you just walk it past customs.
Hein
What part of the "100-240VAC worldwide voltages " in  "Specifications:"
on http://www.nuforce-icon.com/Product-Icon.htm do you not understand ?
" Power Adapter - 12-14V, 25W, 100-240VAC worldwide voltages "
rustydoglim
    • www.nuprimeaudio.com
Pay attention to the warranty or upgrade support policy. International distributors will not service the product bought in the USA so you have to send it back to Nuforce.
