OB dual sub servo placement
0 Members and 1 Guest are viewing this topic. Read 8349 times.
dvenardos
« on: 28 Feb 2009, 12:14 am »
I can't find anything on the recommended placement of OB dual servo sub.
http://www.gr-research.com/pdf/obsub.pdf
How far from the wall or can you just put it sideways in between your mains?
Don
emac
Re: OB dual sub servo placement
« Reply #1 on: 28 Feb 2009, 12:58 am »
According to Danny, they need a couple of feet from the wall in order to sound their best.  Part of why I haven't gotten a pair.  No good place to put them.
dvenardos
« Reply #2 on: 28 Feb 2009, 02:08 am »
Yeah, I am trying to find a way to get an OB/IB sub. It looks like the spot were I could do IB is not optimum and so I am racking my brain to try and find a workable solution.
TRADERXFAN
  • Trillions will vanish... it's a debt blackhole.
    • GALLERY
« Reply #3 on: 28 Feb 2009, 03:22 am »
Where did Danny say that? I must have missed it.
I had set mine up as Linkwitz recommended here...
"A woofer with two 12 inch drivers arranged for dipole radiation. The woofer should be positioned at the same distance from the listening place as is the panel, and preferably along the side wall, for optimal summation of sound outputs in the crossover frequency range, and minimal excitation of room modes." He also suggested somewhere to angle it toward the listening position. You might want to give this a try and see how it works in your room.  I need to try pulling mine out from the wall and see if I notice any improvement.
-Tony
dvenardos
« Reply #4 on: 28 Feb 2009, 03:36 am »
Does that mean sidewall at equal distance of mains? :scratch:
I have never heard that recommendation.
emac
« Reply #5 on: 28 Feb 2009, 04:04 am »
I'm not sure that he wrote it anywhere online.  But that's basically what he said when I emailed him about it.
dvenardos
« Reply #6 on: 28 Feb 2009, 10:55 am »
Okay, let's get creative, how about some kind of ceiling mount OB design?
I know you guys are up for the challenge.  aa
TRADERXFAN
    • GALLERY
« Reply #7 on: 28 Feb 2009, 05:50 pm »
Well you must have it some distance from the rear wall... maybe thats what he was saying in that email?
The Linkwitz suggestion was equidistant from the midrange. So in a theoretical example, if you sat in the middle of a room, and were 10 feet from the left and right speaker, you would want to be 10 feet from the sub, in the same arc. Hopefully with the sub along the side wall, angled towards the listening position.
Whereever you put it, keep in mind that the bass is more directional on this design so if its on the ceiling or something you should angle it.
-Tony
emac
« Reply #8 on: 28 Feb 2009, 07:59 pm »
-Tony
Yep, some distance from any walls or any other objects.  Just like other OB or omni-directional designs.  The equidistant idea also seems very reasonable as well.
dvenardos
« Reply #9 on: 28 Feb 2009, 08:00 pm »
So, you are saying something like this is optimum?
I think that "some distance" is the problem that Ed and I have. I have 8' to the wall, so 3' from the wall would put it practically in my lap. The same reason I can't do OB speakers. I have 15" from the rear of my speakers to the wall.
Danny Richie
« Reply #10 on: 28 Feb 2009, 09:14 pm »
Linkwitz recommends 3 feet out from the rear wall as a minimum for an open baffle design, and I would recommend the same.
emac
« Reply #11 on: 28 Feb 2009, 09:52 pm »
Yep, what I thought.  I can get the speakers 3' from the wall, but I have no room for the sub unless I put it in the center of the room.  And then my wife may have some issues.
Danny Richie
« Reply #12 on: 28 Feb 2009, 09:54 pm »
You know, a single sealed box servo sub can be quite good.
Stereodude
« Reply #13 on: 1 Mar 2009, 12:30 am »
Why go with a single 12" driver when you can go dual?  :lol:
Danny Richie
« Reply #14 on: 1 Mar 2009, 03:27 am »
You're right. A pair of them in a sealed box, even better.
EARGASM
  • No thanks.
« Reply #15 on: 1 Mar 2009, 07:23 pm »
Removed by member.
« Last Edit: 25 Sep 2009, 04:04 pm by EARGASM »
dvenardos
« Reply #16 on: 2 Mar 2009, 02:57 am »
Yes! Definately go for a pair in a sealed box!!!  :green: There is no way you will ever regret it!
Yes, but us idiots need a box plan to do that. :)
Danny Richie
« Reply #17 on: 2 Mar 2009, 02:17 pm »
See two different cabinet plans at the bottom of the page.
http://www.gr-research.com/index.asp?PageAction=VIEWPROD&ProdID=139
EARGASM
  • No thanks.
« Reply #18 on: 2 Mar 2009, 03:33 pm »
Removed by member.
« Last Edit: 25 Sep 2009, 04:05 pm by EARGASM »
Stereodude
« Reply #19 on: 2 Mar 2009, 03:52 pm »
I think his point was that it's not for a dual driver one box sub.
