Line level switch?
0 Members and 1 Guest are viewing this topic. Read 932 times.
jholtz
Line level switch?
« on: 26 Feb 2009, 07:29 pm »
I'm looking for a simple line level switch that will allow me to switch between two sources. Simple, transparent and inexpensive are what I'm looking for. I know there are very inexpensive switches available but I want one that doesn't add grunge to the signal.
Any recommendations?
Thanks in advance for the feedback!
Jim
Glen B
Re: Line level switch?
« Reply #1 on: 27 Feb 2009, 03:37 am »
Your best bet is probably DIY.  I would wire a DPDT mini toggle switch [smaller switch, shorter signal path], three pairs of high quality RCA jacks and premium hookup wire wire in a small aluminum Radio Shack project box.  Keep wire lengths to an absolute minimum and use a fine quality solder like WBT or Cardas quad eutectic.
Rich Carlson
« Reply #2 on: 27 Feb 2009, 11:54 am »
The Niles AXP-1 works well, and sounds fine to me.
