0 Members and 1 Guest are viewing this topic. Read 12633 times.
If you use the CA15RLY woofers then it will probably look a lot like this with a RAAL ribbon tweeter:http://www.salksound.com/SongSurround.shtml (SongSurround II, MTM version)but I'd look into the ER15RLY woofers or the SB Acoustics 5" woofer, just me $.02
Quote from: kip_ on 19 Mar 2009, 09:34 pmIf you use the CA15RLY woofers then it will probably look a lot like this with a RAAL ribbon tweeter:http://www.salksound.com/SongSurround.shtml (SongSurround II, MTM version)but I'd look into the ER15RLY woofers or the SB Acoustics 5" woofer, just me $.02 Thanks, Rick did mention that he liked the SB Acoustics better, so I may go that route. As far as the veneer goes, what are my choices?
Rick I am interested in purchasing one of these extreme MTM using RAAL/Seas. This will be my first jump into the high end audio circle, now I'm wondering if there is a sample pic of the speaker? I would like to know what it looks like before purchasing also the size of the thing
I mostly listen to Rock, but will probably try out some other genre if the speakers is as good as it looks on paper
I would be into a (very) high efficiency version. Whatever is required to give me what I am hearing now with a smaller footprint. I love it...so do my friends...but i live with my wife.The big RAAL with a PHY or Seas Exotic might work. There is also a BIGGER RAAL but it is cost prohibitive for me. Thanks,Chris
I mostly listen to Rock, but will probably try out some other genre if the speakers is as good as it looks on paper. But it will also be used in HT and gaming.For the combination of RAALS and your preferred choice of SB Acoustics, which would you suggest, sealed or vented?I'm still not caught up on all the nuances of the term so could you also explain the benefits of either sealed or vented box?Of course, now my hardest choice would be the veneer that's always a hard oneAlso I will be adding a sub woofer later on into my setup, not sure if that changes anything but please take that into consideration
Quote from: chrismercurio on 20 Mar 2009, 02:59 amI would be into a (very) high efficiency version. Whatever is required to give me what I am hearing now with a smaller footprint. I love it...so do my friends...but i live with my wife.The big RAAL with a PHY or Seas Exotic might work. There is also a BIGGER RAAL but it is cost prohibitive for me. Thanks,ChrisWhat about the acoustic elegance/Lambda woofers? A few people rave about them and they have very high sensitivity.
The sub that I am interested in getting would be SVS PB13-Ultra or Epik Conquest, ofcourse these are going to take a bit more saving up for. I am guessing these two woofers would integrate well with the speakers?
