SOLD: Monarchy Audio SE-100 Delux Class A (100 watts per channel)
0 Members and 1 Guest are viewing this topic. Read 1527 times.
shaizada
$old
Incredible sounding pure Class-A monoblocks. Parting out my second system so check out my other Uher Be-718 ad in the speaker section if you like.
These amps sound amazingly smooth really grip the drivers well. I think of them as gentle giants as they are big in sound and smooth in sound delivery if required. There is hardly any heat at all and are cool to the touch which is amazing for 100 Class-A watts. Dimensions are small, so they are not a the typical Class A beast.
From Monarchy Audio site:
Output : 100 Watts RMS on 8 Ohm, 200 Watts on 4 Ohm.
This Amp will operate into 2 Ohms at even higher outputs but forced air cooling of the heatsinks is required
Circuit Topology : Two Singled-Ended Gain Stages driving a complementary Class A Output bank, which incorporates 8 matched Power MOSFETS, rated at 150 Watts each, for a total dissipating power of 1,200 Watts !
Construction : All 3/8 inch thick Aluminum extrusion (totally free from magnetic hum) 450VA toroidal transformer, 60,000 MFD of filtering capacitors, Mil-spec transistors, all built on a precision machined aluminum chassis.
Sound Quality: The Single-ended topology coupled with Pure Class A output circuitry gives the listener the coherence, layering and transparency that re-assert what music is all about
Dimensions :   Front Panel 9" X 4" X 1/2" thick
Depth of Unit 12 inches
Weight :   25 lbs (50 lbs for a stereo pair)
Fronts are excellent and just a few small nicks on the fins. Nothing obvious and would have to look very closely. Shipping will be a fixed $40 and amps will be packed safe and double boxed. Maple bases are not included. Kindly add 3% if using paypal.
I'll pay shipping in the CONUSA.
Thanks for looking folks!
« Last Edit: 25 Mar 2009, 12:30 am by shaizada »
shaizada
 :thumb:
100 Class A watts that actually runs cool is really a blessing guys.  You don't have to deal with the heat and is a showcase for good design.
shaizada
Sweetness of tubes, drive of a solid state...ready for a new home.
shaizada
Why are these still here?  :scratch:
Oh yeah, cuz we want to BUMP!  aa
shaizada
up up and away :banana piano:
