10.5 Tonearms
0 Members and 1 Guest are viewing this topic. Read 2467 times.
AudioSoul
10.5 Tonearms
« on: 23 Feb 2009, 09:32 pm »
  Anyone using one? What TT do you have it mounted to?....... 8)
TheChairGuy
Re: 10.5 Tonearms
« Reply #1 on: 24 Feb 2009, 01:03 am »
Do you mean 10 or 10.5" tonearms in general...or the VPI 10.5 and or 10.5i tonearms specifically?
John
Wayner
Re: 10.5 Tonearms
« Reply #2 on: 24 Feb 2009, 01:31 am »
Most tables equiped with the longer arm are larger just cause they need the room.
Wayner
TheChairGuy
Re: 10.5 Tonearms
« Reply #3 on: 24 Feb 2009, 01:39 am »
Maybe so, Wayner :)...but the sole example of a 10" arm I have (attached to the JVC QL-Y66F) produces piano will less 'crunch' (distortion) than any other I've ever used (including the seriously pricey $2700 Origin Live Illustrious I have).
The 10% better tracking translates, I think, to lower distortion that I can hear.  My next table will likely have a longer-than-9" arm because of this...it's a step in the right direction for vinyl progress I think.
OP/AudioSoul...I have on order for a while now one of VPI's new Classic tables...which comes replete with their 10.5i arm.  So, I'll be able to provide feedback on it at a later date (don't know how long that will take...tooling is taking a while for it)
Regards, John
Wayner
Re: 10.5 Tonearms
« Reply #4 on: 24 Feb 2009, 01:44 am »
Oh yes, the longer arm makes for a flatter arc, which produces less distortion. In the old days, radio stations played records for broadcast on tables that had very long arms, like 14".
Wayner
twitch54
Re: 10.5 Tonearms
« Reply #5 on: 24 Feb 2009, 09:52 pm »
VPI Aries III, 10.5i arm
BobM
Re: 10.5 Tonearms
« Reply #6 on: 24 Feb 2009, 10:02 pm »
The longer tonearms "theoretically" should produce music with less distortion, due to the shallower arc. But there's other factors to be considered also, like the rigidity of the arm, the mass/compliance resonance frequency, it's tortional stability, etc. It's just as important to find a long arm that matches your cartridge as it would be on a shorter arm, otherwise a shorter arm with a better cartridge match could outplay it. There's still lots of good 9" arms that are considered reference grade for this very reason.
Bob
AudioSoul
Re: 10.5 Tonearms
« Reply #7 on: 25 Feb 2009, 03:12 pm »
  The reason for my question is, I bought a Jelco 10.5 arm off of a guy on Agon.
  Now I need a table for it. It doesn't seem like there are many tables designed for a 10.5" or 12" arms. I may have to go to my TT parts stock and build one. I have the skills. Thanks for all your responses so far........ 8)
TheChairGuy
Re: 10.5 Tonearms
« Reply #8 on: 25 Feb 2009, 03:53 pm »
You'll likely need to build your own as (or at least armboard), as even if a table has been designed to use a 10.5 or 12" arm, it's likely not a JELCO/Linn mount.
Glad you have the skills to do it  :thumb:
John
