Mixing power amps
0 Members and 1 Guest are viewing this topic. Read 1065 times.
AnthonyH
Mixing power amps
« on: 23 Feb 2009, 04:20 pm »
Hi
I have the chance to buy a 3B-ST to go with my 4B-ST, bi-amping my PMC OB1 speakers. Does it make sense to use two different power amplifiers or should I rather get another 4B-ST to match the other?
AnthonyH
Re: Mixing power amps
« Reply #1 on: 24 Feb 2009, 03:42 pm »
 :oops: After a quick search on the Bryston Circle:
From James:
One caution - make sure that the 2 amplifiers you are using have the same GAIN. They can be different power levels aslong as they have the same gain. With Bryston amplifiers you can mix and match any power range and still maintain the same gain characteristics.
So please ignore (some more  :wink:) my stupid question!
