Differences in early BP20's and newer Bp20's in sound quality.
0 Members and 1 Guest are viewing this topic. Read 2059 times.
dannyp
Does the first BP20 with the power switch on the front have the same quality of sound as the later BP20's?
Or is it between the older 0.5B and the newer BP20's?
Dan
« Last Edit: 23 Feb 2009, 06:23 am by dannyp »
  • The Demo is Everything!
    • http://www.bryston.com
Dan
Hi Danny,
The guts of the BP20 has not changed much over the years just the power supply.
james
kmanusa
Hi Danny,
james
[/quote]
James, can you comment on the different power supplies for the BP-20/25 series?  I have a BP-20 made in 1999 and a BP-25 made in 1996.  The BP-25 has an early version of the BP-PSR whereas the BP-20 has a much later revision of the BP-PSR that includes a detachable AC power cord.  How do these compare with, say the MPS-1?
dannyp
Is there an audible difference between pre-amps with the power switch on the front of the pre-amps compared to the later pre-amps.
In particular, the power supply (BP-PT)?
And is there an upgrade available for the early BP-20 with the BP-PT power supply?
Last question. Was the change due to performance?
« Last Edit: 23 Feb 2009, 11:22 pm by dannyp »
Hi Danny,
This is a Mike Pickett question as he was invloved in the MPS-1 and MPS-2 design. I have passed it to him.
james
SFOX
James
Is the 'MP' in MPS1 and MPS2 linked to Mike Pickett as the 'ST' is linked to Mr Taylor ...
James
Correct.
james
