$7500.00 chipamp revealed
0 Members and 1 Guest are viewing this topic. Read 2729 times.
sendler
« on: 21 Feb 2009, 02:41 pm »
Ever seen the inside of a $7500.00 chip amp?
http://www.shine7.com/audio/jeff.htm
Check out the nice review.
http://www.audioasylum.com/forums/amp/messages/7578.html
Maybe I need to try these chips again and use a few more of them this time. I didn't pay attention at the time, what with all of the fervor surrounding them, but a gainclone with 1 LM3886 per channel is only making 38 watts into 8 ohms which may go a long way towards explaining why my TDA7250 amps sounded so much better.
Re: $7500.00 chipamp revealed
« Reply #1 on: 21 Feb 2009, 05:00 pm »
Looks like more than a couple of chips in there to me   :D
Gaara
« Reply #2 on: 21 Feb 2009, 05:40 pm »
Wow.  I think I will stick with my $160 LM3886 clone.  Hell my BPA200 4ch amp has 16 of those chips and was ~$650.
P.S.  OP Might want to look into a BPA200/BPA300 for higher powered clones
dweekie
« Reply #3 on: 22 Feb 2009, 05:16 am »
Have you looked into the LM4702 (stereo) and LM49811 (mono) chips?  They use external transitor/fets, but I hear they are supposed to be the best that National Semiconductor has to offer right now.
dweekie
« Reply #4 on: 22 Feb 2009, 10:45 pm »
Scott, I'm not sure if you read this, but these are some musing from a (recently) former National audio circuit designer.
http://www.diyaudio.com/forums/showthread.php?s=&threadid=132471&highlight=
Jon L
« Reply #5 on: 22 Feb 2009, 11:49 pm »
I hate to admit it, but Rowland 10 sounds quite nice.  The good power supply and sturdy chassis/resonance-control must be doing nice things.
Having said that, my DIY 3886 amp also sounds quite nice for way, way less $  :green:
sendler
TDA7250 sounds great
« Reply #6 on: 23 Feb 2009, 12:15 pm »
I really like the TDA7250 right now. It sounds amazing with cheap TIP143/147 outputs. Much better than a single 3886 with the same power supply and doesn't cost that much more to build. I might try the LM49811 but it's funny that National doesn't seem to post a recommended schematic with parts designations. Just a rough application guide.
I have 8 3875s ordered to try a bridge/ parallel before forming a final impression. I can get the best true balanced/ bridged sound from them since I have a nice balanced output from my direct out modified DEQ2496 so I won't even need to add a splitter in front of the amps.
sendler
LM4702 schematic
« Reply #7 on: 23 Feb 2009, 10:22 pm »
Now I found the nice application notes for the LM4702 which would also apply for the 49811.
http://www.national.com/an/AN/AN-1490.pdf
Great notes they put together for that chip. It actually discusses differences in the circuit based on listening! No wonder they fired all of those guys. We can't have any of that going on around here.
I will probably give those a try as well before I commit to boards for the 7250. But so far, it has beaten all comers.
