removing secondaires from a torroid
0 Members and 1 Guest are viewing this topic. Read 1617 times.
sts9fan
« on: 18 Feb 2009, 10:52 pm »
What should I do?  Just clip the leads?
whubbard
Re: removing secondaires from a torroid
« Reply #1 on: 19 Feb 2009, 02:12 am »
Just wondering, but why would you ever want to remove them?
-West
sts9fan
« Reply #2 on: 19 Feb 2009, 01:05 pm »
Would you want unused hot leads floppin around you case?  Or should I just coil em up and tape them down?
JoshK
« Reply #3 on: 19 Feb 2009, 03:03 pm »
Coil up and secure them with tape or whatever is my advice.  Cutting them off potentially ruins them for unforeseen applications in the future.
whubbard
« Reply #4 on: 19 Feb 2009, 03:43 pm »
That was what I was thinking. You could also just put a wire cap on it, and then you could just forget about it. I just feel it would be a shame to ruin a toroid when there are a lot of options for covering wire leads.
-West
BillB
« Reply #5 on: 19 Feb 2009, 04:11 pm »
You can always cut them shorter than what they are, but make sure they remain solderable and reachable. I would not want a foot of coiled junk in my chassis either but 4-5" should be managable.  :thumb:
sts9fan
« Reply #6 on: 19 Feb 2009, 04:21 pm »
well it would not be ruined either way.  It would still be a 2x18vac torroid
