For Sale: H2o Audio M250SE Special Edition Monoblocks
0 Members and 1 Guest are viewing this topic. Read 3661 times.
AudioFanKJ
Relisting 11/01/2009 - reduced price: $3,250 OBO
H2o Audio M250SE (Special Edition Monoblocks) for sale.
This pair of monoblocks is the absolute latest and top of the line offering from Henry Ho of H2o Audio.  These amplifiers employ use of the ICE module, however couple them with conventional torroid transformers.
This pair of monoblocks takes Henry's former top of the line M250 Signature monoblocks and improves upon it in several aspects.
Some of the details are considered proprietary by Henry - however some of the improvements in the H2o Special Edition Mono's versus the Signature Monos are:
The Signature Mono's used a 800vA transformer per monoblock. The Special Edition mono's upgrade this to a 1,000vA transformer per mono.
Henry states both the quantity and quality of the input caps, input coupling caps, output caps, and output coupling caps are all improved, everything is voiced per Henry, as for the type and sizes of the capacitors, this information was requested to be kept proprietary.
In addition to the above changes, all internal wiring and other tweaks and modifications have been implemented however remain proprietary info.
Info from website:
Power Supply - Traditional Toroidal Transform
Output Power - 250watts/500watts into 8/4 ohms
THD+N - 0.1% , 10hz < f < 20khz at 500watts
Voltage Gain - 27dB
Bandwidth - 6hz-80khz into 8ohms
Input Impedance - 8 Kohms
Output Impedance - 0.005 ohms
Minimum Load Impedance - 2 ohms
Dyanmic Range - 117 dB
Inputs - Both Single Ended & Balance are available
Outputs - Bridge Balance with Dual Binding Posts
Chasis Dimension - 15"W x 15.5"D x 6.5"H
Weight - 63 lbs net - each
New Price - $7,495.00 USD a pair
I am the original owner, always used in a pet, smoke, & child free environment.
Conservatively rated at 9/10 as they appear new. These are in extremely pristine condition. Have original boxes, owners manual, etc.
I have owned both the H2o Signature monos (M250SA) and the H2o Special Edition monos (M250SE). I can personally attest for sonic improvements in overall greater sense of ease and power, an improvement in finesse, an improvement in transparency, improved micro and macro dynamics, as well as a greater sense of organics and liquidity in the midrange.
This would remain my reference pair of monoblocks if my system has not taken a drastic change of direction to high efficiency speakers and low powered single ended triode (SET) amps.
New Price $7495.  Asking $3,250 obo.
Please email with any questions. Money Order / Cashier's Check preferred, PayPal & Credit Card accepted with 3% fee.
Please review my feedback on www.audiogon.com under the same user name and purchase with confidence.
« Last Edit: 2 Nov 2009, 02:18 pm by AudioFanKJ »
AudioFanKJ
Re: For Sale: H2o Audio M250SE Special Edition Monoblocks
« Reply #1 on: 24 Mar 2009, 05:17 pm »
11/01/09 reduced price to $3,250 OBO
« Last Edit: 2 Nov 2009, 02:19 pm by AudioFanKJ »
AudioFanKJ
« Reply #2 on: 2 Nov 2009, 02:19 pm »
Relisting at reduced price: $3,250 OBO
