Dedicated AVA Headphone Amplifier (with DAC?) ?
0 Members and 1 Guest are viewing this topic. Read 5455 times.
USAudio
« on: 17 Feb 2009, 01:47 am »
Has AVA considered producing a dedicated headphone amplifier?
Lots of headphone related information here: http://www.head-fi.org/
Edit: or perhaps even a combination headphone amp, preamp and DAC in one box???   aa
http://www.audiocircle.com/index.php?topic=64965.msg596353#msg596353
« Last Edit: 25 Feb 2009, 10:14 pm by USAudio »
BradJudy
Re: Dedicated AVA Headphone Amplifier ?
« Reply #1 on: 17 Feb 2009, 02:19 am »
Frank mentioned the possibility of a small one-board Insight that could be built as either a pre-amp or a headphone amp:
http://www.audiocircle.com/index.php?topic=63173.msg570935#msg570935
Sounds like a pre-built board, but the rest of the build would be DIY.  It could be a fun for the Head-Fi crowd, but it doesn't seem clear if/when it might come to be.
USAudio
« Reply #2 on: 18 Feb 2009, 07:01 pm »
Sounds good but still seems like the headphone section would be a bit of an afterthought.
I was thinking of something like a pure dedicated headphone amplifier that receives the full design/engineering attention that Frank's amplifiers receive.
Something like that could be a big hit at head-fi.org.
turkey
« Reply #3 on: 18 Feb 2009, 07:15 pm »
The Insight headphone output doesn't sound like an afterthought to me.
USAudio
« Reply #4 on: 18 Feb 2009, 08:11 pm »
Good, glad to hear that!
USAudio
Combination DAC and headphone amp ?
« Reply #5 on: 22 Feb 2009, 08:44 pm »
To carry this a step farther, how about a combination AVA headphone amp, pre-amp AND DAC all in one box?   aa
Something like the DAC1pre from Benchmark:
http://www.benchmarkmedia.com/system1/digital-analog-converter/dac1-pre
or m902 from Grace Design
http://www.gracedesign.com/products/m902/m902.htm
or Meier Corda Symphony:
http://www.meier-audio.homepage.t-online.de/symphony.htm
or Lavry DA11
http://www.lavryengineering.com/productspage_pro_da11.html
« Last Edit: 4 Mar 2009, 01:43 am by USAudio »
dB Cooper
« Reply #6 on: 22 Feb 2009, 11:19 pm »
If you peruse the AVA preamp product pages a little bit, you will discover that all AVA preamps- be they tube, SS, or hybrid- already have headphone amps built in. I can vouch that they have REAL NICE headphone amps. Don't be fooled by some "boutique" headphone amps being as (or more) expensive than some AVA preamps.
This pre/dac question has come up before, and IIRC Frank didn't feel that the unit was sufficiently quiet for his liking. It is a great concept, fewer boxes, fewer wires, but concept and execution don't always match up.
Dan Kolton
« Reply #7 on: 23 Feb 2009, 01:13 am »
How about a pre-pre for moving coil cartridges (including provisions for adjusting load resistors)?
dB Cooper
« Reply #8 on: 23 Feb 2009, 04:07 am »
Or a complete Insight set for my first gen MosFet SCA80 (known around these parts as "Old Faithful")   aa
Still gives a good account of itself despite its age, but getting noisy now, especially noticeable thru phones, which is how I listen a lot of the time
Will surprise you when you plug in yer 'phones though
Hey, I can dream, Can't I  :drool:
oneinthepipe
  • Trainee
    • Salk Signature Sound/Audio by Van Alstine two-channel system
« Reply #9 on: 23 Feb 2009, 04:52 am »
Or my SCA-50/Omega 50!
dB Cooper
« Reply #10 on: 23 Feb 2009, 05:51 am »
What he said!
Why not, they're the same size box... Different power xformer, -80 might need a 'transplant'
It'd sound as good or better than a lot of hi-buck 'boutique' headphone amps, I'd wager aa
USAudio
« Reply #11 on: 23 Feb 2009, 06:42 pm »
That's too bad as the units already out on the market are very popular!
If AVA could put one out for less than $2000USD it could prove to be quite successful.
A couple more that I didn't list in my above post:
HeadRoom Desktop: http://www.headphone.com/products/headphone-amps/the-desktop-line/headroom-desktop-amp.php
Lavry DA11: http://www.lavryengineering.com/productspage_pro_da11.html
« Last Edit: 4 Mar 2009, 01:44 am by USAudio »
USAudio
Re: Dedicated AVA Headphone Amplifier (with DAC?) ?
« Reply #12 on: 26 Aug 2009, 06:21 pm »
Something like this: http://www.redwineaudio.com/products/isabellina_hpa
might be interesting from Van Alstine?
boycephoto
« Reply #13 on: 26 Aug 2009, 07:59 pm »
I remember AVA talking about changing the phono circuit in an Insight preamp  (I think) to have enough gain to use a Denon MC.   Not to long ago.  Maybe he is already working on something along those lines for the future????  Only Frank would know.  In the past he recomemded a MC transformer instead of a pre-pre, but that was a long time ago and things do change.
Dave
« Last Edit: 27 Aug 2009, 06:18 pm by boycephoto »
boycephoto
« Reply #14 on: 26 Aug 2009, 08:04 pm »
Mr Cooper,
I like your BS Meter.  Can you change the settings to corespond to the current line of thoughts and answers you are responding to??  If you can, I think I need one too.  :lol:
Dave
avahifi
    • http://www.avahifi.com
« Reply #15 on: 27 Aug 2009, 01:58 pm »
To answer a few questions:
The Insight Phono Stage with gain increased just barely runs out of quietness when used with the Denon DL103.  The last time I tried it was when the phono circuit still was using AD845 chips.  Now that they have been replaced with OPA627s it should be about 3 dB quieter and might just work.  I will try again one of these days when I have time to mount a Denon again.
Combo preamp/DAC is still a project I intend to investigate further.  With some new ideas in progress it might just work.
Dedicated headphone amplifier.  Well darn it it requires a chassis, regulated power supply, toroid power transformer, and most of the same bits as a full preamp except for the switching functions.  Its much more cost effective to get the whole preamp.
Frank Van Alstine
plaf26
« Reply #16 on: 28 Aug 2009, 09:13 pm »
I had a similar experience with a DL103R and my small box T8.  Now using K&K Audio transformer with 32K ohms loading resistance and it's very sweet indeed!  Now I know what they mean by "air" around the instruments and a stable sound stage. :thumb:
