MCH-2C5 Any Intereference with FM or HDTV Antenna/Tuners?
0 Members and 1 Guest are viewing this topic. Read 1268 times.
akopperl
A couple of years ago, I auditioned a Nuforce amp and it caused interference with my HDTV antenna for local channels.  The signal went from 90+ to zero.  As a result, I did not purchase the amp - although I thought it sounded very good. Does the MCH-2C5 exhibit the same issue or has the interference problem been corrected in this amp?
Also, does anyone have any opinions on the performance of this amp.
rustydoglim
    • www.nuprimeaudio.com
Re: MCH-2C5 Any Intereference with FM or HDTV Antenna/Tuners?
« Reply #1 on: 17 Feb 2009, 04:38 am »
MCH-2C5 uses V2 amp board and should not have any interference with FM tuner. This issue has been confirmed with many reviewers and customers more than a year ago. All switching devices have a small amount of interference so you might still get interference on weak FM channels.
