Fuse Help...
0 Members and 1 Guest are viewing this topic. Read 1630 times.
laserboi
Fuse Help...
« on: 14 Feb 2009, 06:06 pm »
I'm a bit embarrassed but I cannot seem to figure out how to remove the fuses in my Stratos.  The area is very tight around each fuse and my fat fingers can't seem to get a good grip on them.  Is there a trick to removing these buggers?  Thanks in advance.
laserboi
Re: Fuse Help...
« Reply #1 on: 15 Feb 2009, 04:11 pm »
Anyone at all that can help?   :scratch:
golfugh
  • Dead Can Dance - Into the Labyrinth
Re: Fuse Help...
« Reply #2 on: 15 Feb 2009, 05:44 pm »
fuse puller from Radio shack
laserboi
Re: Fuse Help...
« Reply #3 on: 19 Feb 2009, 02:46 am »
Well I managed to pry them out of their respective places.  I did a continuity test on all four fuses and they passed with flying colors.  Looks like I'll be making a phone call.
-Pete
golfugh
Re: Fuse Help...
« Reply #4 on: 19 Feb 2009, 03:39 am »
Pete
What's the problem?
laserboi
Re: Fuse Help...
« Reply #5 on: 19 Feb 2009, 04:11 am »
Right channel sounds fuzzy and doesn't seem to have the same volume as the left channel.  Basically I noticed this issue when the vocals moved to the left one day and stayed there.  I went up to the right channel and sure enough, I could hear it but nowhere near as loud as the left and the highs coming from the tweeter were distorted and fuzzy.
I've since hooked up an old Jolida 1501 and the speakers sound fine.
-Pete
golfugh
Re: Fuse Help...
« Reply #6 on: 19 Feb 2009, 04:16 am »
Call Klaus!  I'm sure he's up. :)
laserboi
Re: Fuse Help...
« Reply #7 on: 19 Feb 2009, 04:43 am »
Talked to Klaus tonight and I'll be shipping it out sometime this week.
