0 Members and 1 Guest are viewing this topic. Read 13813 times.
Fine... lets play bottom out the market ..Verastarr will sell to anyone mentioning this post for $20 including free Priority mail shipping (PE will cost you $5.99 shipping)...Buy up!!!
byteme,did you ever try the Mapleshade platforms?I am concerned about committing without being able to return. In the past I tried maple cutting boards and I thought it did more harm than good.GW
Byteme, Can you let us know how the platform/conepoints sounds in your system. Did you get the Isoblocks also? I will be using similar set-up. The difference between Mapleshades platform and Timbernation platform is Mapleshades is solid Maple and kiln dried. The Timbernation is multiple pieces glued together and air dried. I'm ordering from Timbernation(great prices for custom work). These platforms/Isoblocks?Conepoints will be used under Nottingham Turntable & BPT 2. Also checking out H.A.L.'s Big-Cup Tend ...
Nope, however these appear to be substantially similar and substantially cheaper. My comments above refer to the look and service. I haven't as of yet, had a chance to listen. I will, however, say this. I noticed a difference for the better when I put the Powervar on Mapleshad ...
- Yes these are edge grain, multi piece, boards as opposed to Mapleshade which is one piece (probably edge grain) and chopping block boards which are typically end grain...
