New N3 kit (Neo series)!
0 Members and 1 Guest are viewing this topic. Read 46115 times.
Golden
Re: New N3 kit (Neo series)!
« Reply #180 on: 4 Jun 2009, 10:29 pm »
sveetsnelda, that's a very nice model.  You don't happen to have a version with layers broken up, do you?
sveetsnelda
« Reply #181 on: 5 Jun 2009, 02:46 am »
For those of you who downloaded the model when I originally posted it, please delete it and download the new one.  I accidently made the speaker 3/4" too tall.  The new model has No-rez added and the dimensions have been triple checked.  New pictures added to original post.
sveetsnelda
« Reply #182 on: 5 Jun 2009, 02:47 am »
What do you mean by "layers broken up"?  Do you mean with the panels removed?  Every piece of wood and piece of foam in the model is a separate component.  You should be able to select it and move it around without doing anything to the model.  If you need help, let me know.
Golden
« Reply #183 on: 5 Jun 2009, 01:52 pm »
Layer's are simply a way of making it very easy to hide and show various groups, without having to move them, etc.  So a single click, for example, gets rid of the front baffle, and then brings it back, without having to worry that I (probably) would slightly messup the dimensions while moving things around ;)  PM if my explanation made no sense, I can show you what I mean!
Love the model, should be a real help to future DIYers! If you get bored, do the OB-7 Plus!  :thumb:
sveetsnelda
« Reply #184 on: 5 Jun 2009, 06:36 pm »
Nice  :)  I didn't know that was possible (still learning SketchUp).  Layers have been added to the model.  :D
EARGASM
  • No thanks.
« Reply #185 on: 14 Jul 2009, 09:46 pm »
Removed by member. Contact GR RESEARCH for flat pack info.
« Last Edit: 25 Sep 2009, 03:16 pm by EARGASM »
laserman
  • Ambiguous-Optimist
« Reply #186 on: 15 Jul 2009, 02:56 pm »
Eric,
A friendly bump and I added the picture so it would show in the thread.
Lou
EARGASM
  • No thanks.
« Reply #187 on: 15 Jul 2009, 06:03 pm »
Thanks, Lou.
Now someone come and get 'em - I'm waist neep in speakers over here...
ttan98
« Reply #188 on: 28 Jun 2011, 11:32 pm »
Danny,
I like to use the N3 kit as a 2 way stereo, in a sealed enclosure, I have 3 questions:
a. Would there be any change to the x-over(I suspect not)?
b. There is no problem with Neo3 crossing over at 1.8 kHz?
c. What is the lower F3 in a sealed enclosure(I calculated to be 90Hz, it that about right)?
a response please.
Danny Richie
« Reply #189 on: 29 Jun 2011, 01:10 am »
That version is called the N3S.
There would not be any change to the crossover.
No issues at all.
By the numbers, yes. In room response though will likely be -3db in the mid 70's to upper 60's depending on your room.
