Other Stuff
Archived Manufacturer Circles
NuForce
Upgraded Power Supply for the ICON
0 Members and 1 Guest are viewing this topic. Read 1877 times.
face
12 Feb 2009, 01:36 pm »
What difference, if any, will this make if the unit is only used for a DAC/Headphone amp?
TIA,
Mike
face
Re: Upgraded Power Supply for the ICON
14 Feb 2009, 05:48 am »
I'll take that as none.
rustydoglim
Industry Contributor
Reply #2 on:
16 Feb 2009, 02:07 am »
Yes, none if only headphone amp or DAC is used.
We only recommended the bigger power supply upgrade if Icon has to drive speaker and line out at the same time.
Some speakers will also benefit from the bigger power supply.
LejfK
Reply #3 on:
16 Feb 2009, 05:49 am »
Would you also recommend it if you're using the Nuforce sub with the Nuforce speakers?
rustydoglim
Reply #4 on:
17 Feb 2009, 04:38 am »
Yes, if the Icon has to drive speaker and line out at the same time, we strongly recommend getting the bigger power supply.
Jason
Other Stuff
NuForce
