FS: Lyngdorf TDAI-2200 Integrated amp with Roomperfect and A/D CARD
0 Members and 1 Guest are viewing this topic. Read 2717 times.
connorjr33
Top of the line Lyngdorf TDAI-2200 INTEGRATED HAS ALL THE OPTIONS AND IS IN "ASNEW" CONDITION WITH LITTLE USE. Retails for $7,200.
f the Lyngdorf Audio products look familiar, it is no coincidence. Peter Lyngdorf, whom you may remember from Tact Audio, is now out on his own and producing the same cutting-edge products that his customers have come to expect.
Just purchased dealer demo with matching CD Player (see other listing) and they are quite impressive together using digital connection. Had not gotten to try the roomperfect which I understand makes a huge difference and is what Peter Lyngdorf is best known. This is the top of the line TDAI-2200 with all options and retails for $7,200. I jumped the gun thinking I could sell my Musical Fidelity KW250S but no takers and not willing to give that away so I have too many components.Like to get this again once I sell the KW250 but looks like that will take some time or I will have to weaken on it's price which not willing to do now. Anyway this unit is great price and the black unit which has original box, manual, remote, and room correction mic kit. 2 seperate boxes for shipping. Paypal fine but please add 3.5% to cover fee.
August 2007
TDAI 2200
The Absolute Sound, USA
Golden Ear Award
“It is easy to get used to a system and forget the extent to which the room around it is affecting negatively what (one hopes) is the really good speaker system one bought. The RoomPerfect sets out, not to change your speakers utterly into some pre-existing concept of correct sound, but rather to gently guide your speaker/room combination into the sound you would hear if the room wasn’t deforming the basic sound of your speakers.”
Your Lyngdorf TDAI 2200 will include:
-Analog/Digital converter module
-Room Perfect DSP module
-Lyngdorf Microphone
-Lyngdorf Microphone Cable and adaptor plug
-Microphone stand
-Computer RS-232 programming cable
-Original remote
-Original manual
-Original boxes/packaging.
Specs:
Output power, 4 Ohms 2 x 375 Watt 1KHz, 0.1% THD+N
Output power, 8 ohms 2 x 200 Watt 1KHz, 0.1% THD+N
Nominal load impedance 4 - 8 ohms It is safe to operate the amplifier with no load
Frequency response 0.3Hz-33KHz -3dB points, 8ohms load.
Frequency response 20Hz-20KHz -0dB/+0.2dB 8ohms load
Output impedance 0.025 ohms 20Hz-1KHz
Output impedance 0.4 20KHz
THD+N 0.015% @1W/8 ohms A-wgt.
THD+N 0.02% @1 W/4 ohms A-wgt.
THD+N 0.008% @100 W/8 ohms A-wgt.
THD+N 0.07% @375 W/4 ohms A-wgt.
S/N ratio 107dB A-wgt. Ref. 200 /8 ohms
Dynamic range 133dB A-wgt. Ref. 200 W/8 ohms
Channel separation 90 dB 1 KHz, 200 W/8 ohms
Peak output current +/-40A
Mains voltage range
115 version 100-120V AC, 50-60 Hz
Mains voltage range
230 version 200-240V AC, 50-60 Hz
Power consumption
Standby mode 1.5W
Power consumption
On mode, no output 40W
Power consumption
2 x 37.5 W / 4 Ohms 116W
Power consumption
2 x 300 W / 4 Ohms 820W
Width 450 mm / 17.72in
Depth 440 mm / 17.32in
Height 100 mm / 3.94in
Net weight 14.5 Kg / 32lb
Shipping weight 22.0 Kg / 48.5lb
money order preferred. PayPal accepted too just add 3.5% please.
HAVE EXCELLENT FEEDBACK ON EBAY UNDER SAME USERNAME: CONNORJR33
twilightround
Do you still have this integrated amp for sale?
