0 Members and 1 Guest are viewing this topic. Read 8909 times.
Do you have the super tweeter/ribbon tweeter module?
I HAD one of the first pairs of dB99's that inc the supertweeter module in high gloss black. Albert and the crew actually "painted" the woof black for me so the drivers looked matched,, top to bottom. You go thru life flipping gear and every now and then you have regrets parting with equipment that could really put a smile on your face. For me the dB's were that VSA model. Small footprint, easy to drive with SET's or SS. The beauty of dialing in the bass response and of course the rear firing tweeter made this speaker easy to place in ANY room. The horn/hi sensitivity/SET crowd would not embrace this speaker and the SS crowd felt this speaker was designed for the tube audience. I used this speaker matched with Wavac and Pacific Creek SET's, VAC, and Spectron. Superb match with any amplifier!The segway model now is the Unifield 3's! Tubes or SS,, this is "modeled" after the big 9's in a way smaller package! Spec ribbon tweet,, a horn lover's full range mid, and an outstanding woofer driver,, a 7 vs 10" (dB99). Easy amplifier match, a touch more fussy with placement,, but the most transparent, 3D/holographic sounding speaker you'll find,, at any price!Shortly, the VR4Anni's will be cranking.. VSA has it all!!
