RM10 users
0 Members and 1 Guest are viewing this topic. Read 2388 times.
sjh500
RM10 users
« on: 10 Feb 2009, 02:06 am »
Need help from all you RM10 users on using this amp with my Chapman T-6 speakers, they are 89db 4ohm with a pretty benign impedance curve. My room is 17.5x13.5 with 9.3ft ceilings. I can be listening to jazz and then Radiohead(fairly loudly) and then back to female vocals, so it's pretty diverse. Roger thinks that the 35watts will work well, I guess I am looking for your experiences with speakers that my be similar to mine. They are a 3 way floor stander with a side firing 10" pseudo transmission line woofer. Do you think this combo will work well?Thanks.
rbwalt
Re: RM10 users
« Reply #1 on: 10 Feb 2009, 03:31 pm »
if roger says it will work well with them i would go with it. my only concern is the 4 ohm impedance. as you know tubes hate low impedance speakers. i know the RM200 and the very scarce RM9SE will drive low impedance speakers with ease. i am not sure about the RM10.if you play music at loud levels then 35 watts probably is not going to do it for you.
rob w.
sjh500
Re: RM10 users
« Reply #2 on: 10 Feb 2009, 09:19 pm »
NO one has any similar experience? I am surprised as this seems like a really active group :scratch: My next question is, what are all you RM10 users using for speakers with success? Thanks
« Last Edit: 11 Feb 2009, 01:01 am by sjh500 »
6BQ5
Re: RM10 users
« Reply #3 on: 12 Feb 2009, 03:29 am »
Klipsch Forte II ... 98/db/w/m
Yup, enough juice.
19.5' x 16' room
KDus
Re: RM10 users
« Reply #4 on: 21 Sep 2009, 11:37 pm »
The RM-10 can drive Lo-Z just fine, and you'll have adequate power for that room.
