SB3 modded Inverted?
0 Members and 1 Guest are viewing this topic. Read 2084 times.
dcktr
« on: 7 Feb 2009, 08:29 pm »
Hi. I have a statement level analog mods
"I modded your SB today. I updated the internal PS. I used the Bybee in the analog section. I installed the V-caps and BlackGate Super E output caps. I also changed the digital output to my latest update. It is still connected and working. If you, by chance, find a DAC you like better than the analog output, you can still use the digital out."
I am using version 7.3.2
I was wondering if it is phase inverted?
Ron
Wayne1
Re: SB3 modded Inverted?
« Reply #1 on: 7 Feb 2009, 09:26 pm »
All of the BOLDER analog modded SB2 and 3 (Classic) analog output signals are phase inverted compared to stock units.
This sticky explains it in a bit more detail.
