0 Members and 1 Guest are viewing this topic. Read 4642 times.
And you can not get around the issue with an active rig. You may think that you have not traded away efficiency, but you have. Whether you use active EQ or just run the bass amp hotter, it's all the same. More voltage, thus more power, is needed in the bass. If it were not less efficient you would not need the extra voltage. Active or passive, it all comes out the same.
Quote from: panomaniac on 7 Feb 2009, 08:51 amAnd you can not get around the issue with an active rig. You may think that you have not traded away efficiency, but you have. Whether you use active EQ or just run the bass amp hotter, it's all the same. More voltage, thus more power, is needed in the bass. If it were not less efficient you would not need the extra voltage. Active or passive, it all comes out the same.With active EQ of low qts drivers, yes, you are still throwing extra energy at the bass...difference being - you're not putting an additional source of resistance between your other amp (hopefully tubed) and your mid/tweets.
Quote from: pedroskova on 7 Feb 2009, 12:24 pmQuote from: panomaniac on 7 Feb 2009, 08:51 amAnd you can not get around the issue with an active rig. You may think that you have not traded away efficiency, but you have. Whether you use active EQ or just run the bass amp hotter, it's all the same. More voltage, thus more power, is needed in the bass. If it were not less efficient you would not need the extra voltage. Active or passive, it all comes out the same.With active EQ of low qts drivers, yes, you are still throwing extra energy at the bass...difference being - you're not putting an additional source of resistance between your other amp (hopefully tubed) and your mid/tweets. And when you EQ the bass you raise the distortion through greater excursion. The bass driver(s) eqed or not should also be high passed electronically with a steep high pass to avoid distortion.The reality of using enough drivers in a line high passed (and low passed or "bandpass") is obvious when you listen to a OB system that will move enough air at low distortion through brute force and surface area.
Quote from: Magnetar on 7 Feb 2009, 12:50 pmQuote from: pedroskova on 7 Feb 2009, 12:24 pmQuote from: panomaniac on 7 Feb 2009, 08:51 amAnd you can not get around the issue with an active rig. You may think that you have not traded away efficiency, but you have. Whether you use active EQ or just run the bass amp hotter, it's all the same. More voltage, thus more power, is needed in the bass. If it were not less efficient you would not need the extra voltage. Active or passive, it all comes out the same.With active EQ of low qts drivers, yes, you are still throwing extra energy at the bass...difference being - you're not putting an additional source of resistance between your other amp (hopefully tubed) and your mid/tweets. And when you EQ the bass you raise the distortion through greater excursion. The bass driver(s) eqed or not should also be high passed electronically with a steep high pass to avoid distortion.The reality of using enough drivers in a line high passed (and low passed or "bandpass") is obvious when you listen to a OB system that will move enough air at low distortion through brute force and surface area. Yep, but there is no reason why one can't use multiple drivers and active EQ. As for distortion, it's been my experience that with enough drivers and active EQ, distortion really doesn't come into play... until you get silly loud, and at that point, I'm not really thinking analytically....probably been drinkin', now that I think about it.
For efficiency rating (2.83 V @ 1 m), for a certain driver effective surface area and baffle dimensions, measured at 40 hz (!), all drivers of equal SD will have the same efficiency (very low). They will differ greatly at higher frequencies, according to their motor strength, but that`s it. The only way to raise efficiency is and always will be, multiplying the number of woofers, period. I`m sick and tired of sensational dipole low bass sensitivity claims...Panomaniac and Magnetar are right on track.regardsmiro
....physics haven't changed a bit.
...sensational dipole low bass sensitivity claims...
I built my first open baffle in 1974 and physics haven't changed a bit. I will argue that there are sensitivity differences on an OB at 40 cycles between same SD drivers although none will be "high efficiency"
OB is great, as long as we understand the trade-offs, right?
