Can't find player? Duet
0 Members and 1 Guest are viewing this topic. Read 1456 times.
Mike Dzurko
« on: 3 Feb 2009, 03:05 pm »
Everything was working great. The other night I noticed the controller was looking for the server which was turned off at the time. Yesterday, turned the server on and it said it couldn't find a player. The controller seems to "hang" looking for the Squeezebox. I rebooted the server and unplugged and restarted the Squeezebox. Any ideas? The controller shows access to the network just fine . . .
Wayne1
Re: Can't find player? Duet
« Reply #1 on: 3 Feb 2009, 03:14 pm »
Mike,
You may need to pull the battery in the Controller to do a "hard reset". Then push and hold the button down on the Receiver until it starts blinking red.
You should be able to go through set up at that point.
I had a similar problem with a freshly modded unit yesterday running under 7.4 beta.
Mike Dzurko
« Reply #2 on: 3 Feb 2009, 03:21 pm »
Thanks Wayne, I'll give this a try tonight!
Mike Dzurko
« Reply #3 on: 7 Feb 2009, 08:59 pm »
It took three tries, but I got music again  :D
Thanks Wayne! One of these days I gotta get another reciever and have you mod it for me.
Wayne1
« Reply #4 on: 7 Feb 2009, 09:20 pm »
You're welcome, Mike.
I'll be here waiting. :wink:
Maybe we can work something out for around RMAF time.
