Record with two holes???
0 Members and 1 Guest are viewing this topic. Read 2454 times.
Blackmore
« on: 1 Feb 2009, 10:59 pm »
My wife bought two of these records on eBay and they both have two holes.  There are other records on the 'bay that have similar hole arrangements.  These were made in 1946-47.  Any thoughts?  (I've already thought of a couple of jokes, but no real good ideas about why there are two spindle holes.)
jqp
Re: Record with two holes???
« Reply #1 on: 1 Feb 2009, 11:22 pm »
Collectors items now! Or are the "cutouts"?
orthobiz
« Reply #2 on: 1 Feb 2009, 11:39 pm »
I can't see the pic...but I don't think it's worth more (like a 1955 double die obverse Lincoln penny)
Paul
richidoo
« Reply #3 on: 1 Feb 2009, 11:40 pm »
Maybe the master tape had really bad "wow," so they drilled a new hole to compensate.  :lol: Or maybe a cigarette burn hole? I think jqp got it right - cutout.
Blackmore
« Reply #4 on: 1 Feb 2009, 11:56 pm »
I don't think even the Nakamichi could fix that much off-set. :lol:  The wife didn't pay very much for these, just strange that they all have that extra hole.  Cut-outs are the most likely idea, but just thought I'd run it by you guys.  Thanks for the comments.
jazzcourier
« Reply #5 on: 2 Feb 2009, 01:55 am »
This is not quite the kitten with two heads,but i will give my thoughts.From the wear on the center spindle it looks like that was the one that was used,no surprise there.The second hole looks like 1] a mistake 2] an aftermarket drill for display purposes 3] now you can start looking for that turntable with two spindles.
chosenhandle
« Reply #6 on: 2 Feb 2009, 07:15 pm »
if you look closely, there are two holes on the other side of the record as well.
(sorry, I couldn't resist).
Think it is a "punch-out"/cut-out and the dude went wild with the punch?
Wayner
« Reply #7 on: 2 Feb 2009, 07:56 pm »
The second off-center hole is an anti-rotation hole used to lock the records in place, to keep them from rotating on the platter from a real heavy old-time tonearm, which could make the record slip.
W
richidoo
« Reply #8 on: 2 Feb 2009, 08:17 pm »
That's a reasonable answer Wayner, actually makes sense - like a keyway to lock a shaft. But is it really true, or you just pulling legs?  :scratch:   :D
thunderbrick
  • I'm just not right!
« Reply #9 on: 2 Feb 2009, 08:32 pm »
Knowing Wayne, that's an easy answer.
 :lol:
Blackmore
« Reply #10 on: 2 Feb 2009, 08:43 pm »
I like Wayner's answer because these are a laminated paper disk, not vinyl.  There's no way that these could be played on a Victrola or Pathe' since the tonearm would just stop them and the platter would spin underneath.
Wayner
« Reply #11 on: 2 Feb 2009, 10:26 pm »
Otherwise, that particular record had poor sales and was punch and put into the bargin bin.  :lol:
Wayner
richidoo
« Reply #12 on: 2 Feb 2009, 10:28 pm »
Cool! Learn somethin new every day! Thanks Wayner and Blackmore
Wayner
« Reply #13 on: 2 Feb 2009, 10:38 pm »
I actually think I remember an extra hole on some of the old Victrolas. Anybody else have one or have you seen one? They usually had green felt on the mat and the old brass tonearm that took steel needles. this was the state of the art turntable, back in the 1930s.
I'm not that old.
Wayner
Dan Kolton
« Reply #14 on: 3 Feb 2009, 12:29 am »
Yeah.  I seem to remember what Wayner describes being found on Victrolas in the parlor of my neighbors' farm houses back when i was a kid during WWll.
