0 Members and 1 Guest are viewing this topic. Read 46808 times.
Quote from: Pacio on 14 Feb 2009, 06:12 pmHello everybody,sorry if this is a stupid question and forgive me if I missed the explanation in the long thread here above, but I have the following issue.I have an analog modded SB3 with v. 15 firmware. I would love to stay with this version also with the new SqueezeCenter 7.4, since I only have one source and I could invert the polarity of my speakers cables. Question is: as soon as I connect the SB3 to my pc with the new server, it tries to do a sw update. I cannot do anything but shut it down. Should I try anything else? Has anybody another analog modded SB3 with v.15 AND the new 7.4?In the end, am I so dummy?? Thanks for your help!Do you have a copy of Mgalusha's firmware selector tool? Send him a PM. I think the tool is still out there.http://www.audiocircle.com/index.php?topic=58778.0
Yes, I have it. Do you suggest let it perform the update and turn it back afterwards to ver. 15? Should it keep this version?
Pacio,If you use Alien BBC plug-in you may want to reconsider using Squeeze Centre 7.4 with Firmware 15 - I had no end of trouble and gave it up.On the other hand if it works let me know what you did Jim
beta versions of SqueezeCentre not being compatible with Alien BBC
Has anybody an idea why the new version should sound better? I tested it and it sounds different. My only guess would be that the conversion from any format to a PCM stream is handled better by the PC than by a SB3/Transporter. In the end of the day, the stream must be converted to PCM so it transfers some load to the PC.I the conversion to PCM is no magic and I cannot believe that Logitech has any revolutionary algorithm for it. I tried it out with the brutefirDRC plugin after the flac has been processed for room correction and converted the stream to PCM with SOX. The sound difference was still there.Would be happy to understand why the sound is different.Regards Klaas
Quote from: Klaas on 19 Feb 2009, 11:02 amHas anybody an idea why the new version should sound better? I tested it and it sounds different. My only guess would be that the conversion from any format to a PCM stream is handled better by the PC than by a SB3/Transporter. In the end of the day, the stream must be converted to PCM so it transfers some load to the PC.I the conversion to PCM is no magic and I cannot believe that Logitech has any revolutionary algorithm for it. I tried it out with the brutefirDRC plugin after the flac has been processed for room correction and converted the stream to PCM with SOX. The sound difference was still there.Would be happy to understand why the sound is different.Regards KlaasYou may want to have a look at this thread HERE...
Quote from: MerlinWerks on 19 Feb 2009, 02:48 pmQuote from: Klaas on 19 Feb 2009, 11:02 amHas anybody an idea why the new version should sound better? I tested it and it sounds different. My only guess would be that the conversion from any format to a PCM stream is handled better by the PC than by a SB3/Transporter. In the end of the day, the stream must be converted to PCM so it transfers some load to the PC.I the conversion to PCM is no magic and I cannot believe that Logitech has any revolutionary algorithm for it. I tried it out with the brutefirDRC plugin after the flac has been processed for room correction and converted the stream to PCM with SOX. The sound difference was still there.Would be happy to understand why the sound is different.Regards KlaasYou may want to have a look at this thread HERE...First off, the Slim forum, and Phil in particular, believes that if you can't measure it then it doesn't exist. They are VERY left brain (which is ok, they design the stuff). More importantly for this test, Phil is using a stock SB3 and a rather pedestrian pc card for a DAC. No offense, but if your system isn't resolving enough, you won't hear the differences between MP3 and SACD. Klaas, personally I think the PCM decoder has improved, and also benefits from more computing horsepower (server side decoding) but I'm just postulating. I hear a difference and it's not subtle (going to 7.4).
Quote from: ted_b on 19 Feb 2009, 03:09 pmQuote from: MerlinWerks on 19 Feb 2009, 02:48 pmQuote from: Klaas on 19 Feb 2009, 11:02 amHas anybody an idea why the new version should sound better? I tested it and it sounds different. My only guess would be that the conversion from any format to a PCM stream is handled better by the PC than by a SB3/Transporter. In the end of the day, the stream must be converted to PCM so it transfers some load to the PC.I the conversion to PCM is no magic and I cannot believe that Logitech has any revolutionary algorithm for it. I tried it out with the brutefirDRC plugin after the flac has been processed for room correction and converted the stream to PCM with SOX. The sound difference was still there.Would be happy to understand why the sound is different.Regards KlaasYou may want to have a look at this thread HERE...First off, the Slim forum, and Phil in particular, believes that if you can't measure it then it doesn't exist. They are VERY left brain (which is ok, they design the stuff). More importantly for this test, Phil is using a stock SB3 and a rather pedestrian pc card for a DAC. No offense, but if your system isn't resolving enough, you won't hear the differences between MP3 and SACD. Klaas, personally I think the PCM decoder has improved, and also benefits from more computing horsepower (server side decoding) but I'm just postulating. I hear a difference and it's not subtle (going to 7.4).Ted,Phil in no way believes that if you can't measure it it doesn't exist.You should be more careful in the future so that you don't so completely misrepresent someone's philosophy.Phil is a professional musician and recording engineer.He has specifically stated that there may well be differences that we can't yet measure.You have acted very irresponsibly with your statement and you owe Phil an apology.
