Neo-1X vs Neo-2X - Which is better?
0 Members and 1 Guest are viewing this topic. Read 1494 times.
Ron
« on: 28 Jan 2009, 04:50 pm »
 Which speaker is better,the Neo-1X or the Neo-2X? I know they both use the same deep back Neo tweeter but the Neo-1X uses a 5-1/4" woofer in a vented enclosure and the Neo-2X uses a 6-1/2" woofer in a sealed enclosure. I haven't listened to either one, but from what I have read they are both reported to be excellent sounding speakers. My question is does one sound or perform any better than the other assuming they are used with a subwoofer?
Danny Richie
Re: Neo-1X vs Neo-2X - Which is better?
« Reply #1 on: 28 Jan 2009, 04:58 pm »
This is true.
I's say that they sound more alike than different. Technically the ported Neo-1X plays a little lower, unless you build the Neo-2X into a small ported floor standing speaker. However, in room responses taken in my room show that the ported Neo-1X doesn't play too much lower than the sealed Neo-2X.
I'd have to say that the sealed box Neo-2X has a little tighter and more well controlled bass and is more ideal for a small room if using it with a sub, especially one of our direct servo subs. That is a killer combo.
S Clark
« Reply #2 on: 28 Jan 2009, 05:12 pm »
I haven't heard the Neo1's, but the Neo2X matched up well in an Austin get together last summer with a custom (and much more expensive) kit from another designer, and even approximated (when matched with 2 of Danny's Servo subs) the sound of Danny's highly acclaimed OB7.
Ron
« Reply #3 on: 28 Jan 2009, 09:53 pm »
 Thanks guys for your replys regarding my question about the Neo-1X and Neo-2X. Much appreciated.
