Trade my Rega Saturn for your Benchmark DAC1 pre...
0 Members and 1 Guest are viewing this topic. Read 1962 times.
Jonathan
« on: 28 Jan 2009, 03:22 am »
Anyone?  aa
HumanMedia
Re: Trade my Rega Saturn for your Benchmark DAC1 pre...
« Reply #1 on: 28 Jan 2009, 04:01 am »
Anyone?  aa
Why are you downgrading to a Benchmark?
Jonathan
« Reply #2 on: 29 Jan 2009, 02:22 am »
Looking for a tad more detailed sound (my old drummer's ears are just not what they used to be). Thinking I could get rid of my preamp, too. Also figured I can use my cheap old Sony NS500V as a transport and be able to listen to the few SACDs I own without having to use two players.
What makes you say this would be a downgrade?
Jon
hoosier21
« Reply #3 on: 29 Jan 2009, 03:41 am »
Jon
You do realize the Benchmark will not pass the SACD through, right?
mr_bill
« Reply #4 on: 29 Jan 2009, 05:14 am »
If you use the preamp function, the BM will pass through the SACD from the player.
orthobiz
« Reply #5 on: 29 Jan 2009, 03:13 pm »
I had the regular Benchmark DAC1, had a Musical Fidelity tube buffer and a cheap CD player. So I had 3 power cords and 6 interconnects.
I switched to the Rega Saturn and have been happy. Looks like I went exactly in the opposite direction! But getting rid of the preamplifier with the Benchmark could be a definite advantage!
Paul
Jonathan
« Reply #6 on: 31 Jan 2009, 04:13 am »
Yes, I would just use the Sony's analog outs for the few SACD's in my collection.
Actually, I owned the first generation DAC 1 and found it to be somewhat uninvolving; I ended up buying a used Sony SCD-1 for dirt cheap and liked it better. The system has completely changed since then, with a different CD player, different amps, preamp and speakers. The DAC1 is also not the same unit as it used to be either. I guess I'm curious, especially in light of the recent glowing feedback on the new DAC1 in TAS and elsewhere.
