0 Members and 1 Guest are viewing this topic. Read 3080 times.
George, where is the best place to buy the XTZ? Did you order directly from the company website or through another site?
Hi George, I am no expert, but I was wondering if you could specify the sitting location, as well.I noticed the relative peaks at around 25 Hz, 39-40 Hz, and 78-80 Hz, with their correspondingly long decay times. The multiplicity of the 39 and 78 made me think of the possibility that you're sitting in or near the antinode of a second- and fourth-order mode whose first-order frequency is around 19 Hz, which would correspond to a room dimension of around 29 feet, which is close to the length of the room. If you're sitting near the center of the room, this could account for the issue with these two frequencies (incidentally, I also noticed a relative null at around 19-20 Hz, and of course, the center of the room would be the node for the 19-20 Hz mode). Moving the listening position either forward or backwards away from the center of the room could potentially help. Otherwise, moving the loudspeaker might be a little tricky because the closest node for the second-order mode happens to be the antinode for the fourth-order mode. But maybe I'm wrong about the 19/39/78 and the listening position, and it's just a coincidence?I don't know about the 25 Hz, and I don't understand how to apply SBIR and non-modal "standing waves" to your case, so I'll have to defer to the experts.
Generally, seated ear position (depending on the exact seating and how tall the listener is) falls somewhere around 40-43". While it's not centered in the height dimension, it's still falling in that 40%'ish range that has some pretty extreme peaks. I don't believe that's the problem in your room though.Bryan
As you can see from the chart above, my reverb times are generally good, but I do have some small issues at 40Hz and 80Hz.
