RM 9 SE balanced option
0 Members and 1 Guest are viewing this topic. Read 2138 times.
dawkimi
« on: 25 Jan 2009, 06:10 am »
Roger,
Can the RM 9 SE be configured for single ended and balanced inputs (like the RM 200)?  Additionally, what is the 8 and 4 ohm power output for the RM 9 SE.  Thanks.
Mike
rbwalt
Re: RM 9 SE balanced option
« Reply #1 on: 25 Jan 2009, 04:47 pm »
dawkimi the power output at 8 ohms is 162 watts and at 4 ohms it is 200. i am not sure about the balanced option. roger only built 18 or 19 RM9SE's and he has only a few left. it simply craps all over the RM9mk1 and 2's. i know i had a mk2 and i have a SE now driving my Merlin VSM MXe's.
rob w.
Roger A. Modjeski
« Reply #2 on: 29 Jan 2009, 01:49 pm »
rbwalt: thanks for fielding the power question.
As to balanced inputs, if one wants good common mode rejection (CMRR = 100 dB in the RM-200) it has to be done with a solid-state device or an input transformer. With a tube input the CMRR will not be more than about 20 dB and be very dependent on the tube gain and gain difference between the two halves. There could be a balance pot to allow the user to improve this number by nulling the cable hum audibly.
