Bias Setting for Tubed Amps - Affected by House Current ?
0 Members and 1 Guest are viewing this topic. Read 1127 times.
Brown
If ones amp is designed to run from 110V to 120V and the house current is 126V does one still adjust to the desired setting for the tube or adjust the setting because of the higher voltage. Thanks.
    I set my output tubes at 4.8 as per manf recco, but recently changed to 4.0. Sounds so much better, tried 20% less then recco at 3.76 even better. Why ? I'm so confused HELP!!!!
richidoo
Re: Bias Setting for Tubed Amps - Affected by House Current ?
« Reply #1 on: 24 Jan 2009, 03:43 pm »
Mfg recommendation might have been determined using different tubes than you're using. Even same brand tubes can vary between batches. Different brands of same tube will behave differently, especially new production versus vintage tubes of same type. And of course you will have a different system and taste than the amp designer, and might not need or prefer the edge/presence that higher bias gives. Bias current is set to nominal current regardless of voltage variation which is usually slight. Bias will still fluctuate with voltage changes like refrg turning on, etc, but that's expected. But it is always safe to turn it down to taste, but you might blow a fuse if you crank it up too far. Turning down the bias current will also prolong the tube life. Sounds like you found a win/win.  I have my tubes turned down a just a couple mA too. They are less fussy.
Brown
« Reply #2 on: 25 Jan 2009, 05:04 pm »
Thanks Rich. Was just wondering if the house current makes a difference. Is there a rule of thumb for adjusting down. Say 20% or any given percentage. Thanks for the help.
