D/A converter in the AVP 17
0 Members and 1 Guest are viewing this topic. Read 1684 times.
bizon
« on: 23 Jan 2009, 11:54 pm »
Hi,
I have looked all over the net for info on this but havent found it. I am wondering what D/A converter for the sound that is mounted in the AVP 17?
Thanks for your reply :)
rustydoglim
    • www.nuprimeaudio.com
Re: D/A converter in the AVP 17
« Reply #1 on: 30 Jan 2009, 02:55 pm »
I remember a dealer did a blind test comparing AVP-17 DAC with Benchmark DAC-1 and the result was even.
AVP-17 is at its end of life sale now so exceptional value as a preamp, DAC and processor!
bizon
« Reply #2 on: 30 Jan 2009, 03:22 pm »
Thanks for your reply Jason. However you did not answer the question :D Do you have the answer?   8)
basso
« Reply #3 on: 3 Feb 2009, 07:13 pm »
Jason- is there a replacement in the queue?  i understood the AVP32 was canceled?
