Here's a really stupid question.
0 Members and 1 Guest are viewing this topic. Read 1575 times.
drphoto
« on: 23 Jan 2009, 08:11 pm »
I got my SW-12FRs today. There is a rubber ring on the mounting flange. Does that stay on or is it there to protect the edge in shipping? If it stays, do you pull the rubber away to insert the bolt so it makes contact against the metal, and then slip it back into place? I've just never seen a driver w/ rubber covering the face of the flange.
Can't wait to get these bad boys hooked up.
Cacophonix
Re: Here's a really stupid question.
« Reply #1 on: 23 Jan 2009, 08:19 pm »
You should be able to insert the screws through the holes on the rubber ring. You might have to wriggle a bit, but they should go through easily enough.
fcraven
  • Don't mess with this baritone
« Reply #2 on: 23 Jan 2009, 08:33 pm »
What he said.
And as a note, if you are a little too exact when you rout the recess and it's a little snug, as soon as you put some paint on the recess walls...it gets even snugger. I ended up using some soapy water to help seat mine.
drphoto
« Reply #3 on: 23 Jan 2009, 09:17 pm »
I don't plan on cuttling a recess, just flush mount. Hell I'll be doing good just a cut a reasonably circular hole! I've done carpentry (framing walls, etc) but no woodworking.
Danny Richie
« Reply #4 on: 23 Jan 2009, 10:25 pm »
Mounting holes in the rubber gasket will line up with the mounting holes in the frame.
I'd go with the W frame if possible. It makes it very solid, and supports it very well. It is also really easy to build.
