Can 7.1 Analogue output can be directly fed to the amplifier?
0 Members and 1 Guest are viewing this topic. Read 1073 times.
cmreddy
Hi All,
dumb question though. Theoretically can i feed the 7.1 Analogue output to the 9B SST and 4B SST directly without a Receiver or an Processor in between?
Thankx..
Cm..
  • The Demo is Everything!
    • http://www.bryston.com
Hi All,
Thankx..
Cm..
Hi Cm,
NO - because there is no way to control the volume assuming the feed component (I assume a DVD player) does not have a variable output.
james
cmreddy
James,
in that case one option could be to buy a really cheap processor (a stop gap solution to SP3) and feed it with 7.1 analog output from a Bluray player which does the latest formats and then connect them to the Amps..
hope this works..
Cm..
PS: I wish SP3 is out by now.. :)
James,
hope this works..
Cm..
Hi CM,
Yes a cheap processor or maybe a low cost reciever with PreOuts to drive the amps.
james
