another NOH is done...
0 Members and 1 Guest are viewing this topic. Read 3200 times.
gonefishin
« on: 2 Dec 2003, 12:16 am »
I got the Knobs John...and assembled the rest of th parts.  I'll miss that thing sittin' there with it's top off...but...it looks good with everything on too ;)
   Here's a link to the short review I wrote http://www.audiokarma.org/forums/showthread.php?s=&threadid=12019
  thanks a bunch!
John Chapman
    • http://www.bentaudio.com
« Reply #1 on: 2 Dec 2003, 01:27 am »
Hello!
Congrats on finishing it up! Thanks for taking time to do the write-up over at audiokharma. I had heard about that site but never been over there.
Keep me posted and when you need that remote mod kit just let me know!
Many Thansk!
John Chapman
www.bentaudio.com
gonefishin
« Reply #2 on: 15 Feb 2005, 11:07 pm »
Hi John,
   Hope everything is well :D
    I have a question regarding the NOH preamp.
    When is enough...enough?
    I'm using the NOH to Bi-Amp my speakers, so I already use two outputs.  I've been thinking of (finally) moving my system downstairs into it's own room.  Which would allow me to hook up my 20Hz horn sub.  Would three outputs out of the NOH be too many?
  thanks,
  dan
John Chapman
« Reply #3 on: 16 Feb 2005, 12:36 am »
Hello!
As long as the net impedance the 3 outputs 'see' is not below 10K or so you will be just fine. I have a few folks running at less than 10K and even that seems o.k. as long as source impedance is low and your sources don't have exceptionally high output impedances.
Many Thanks!
John
gonefishin
« Reply #4 on: 16 Feb 2005, 03:56 pm »
Thanks for the response :)
    dan
