Anybody out there using ATC loudspeakers???
0 Members and 1 Guest are viewing this topic. Read 1507 times.
Mattyboy
« on: 21 Jan 2009, 10:17 am »
I am the proud owner of a lovely pair of ATC SCM 40's....
Would be interested to hear you views on them owners or not and what you are using them with..
Cheers
Matt dude :D
AnthonyH
Re: Anybody out there using ATC loudspeakers???
« Reply #1 on: 21 Jan 2009, 11:15 am »
Hi Mattyboy
Out of interest, what source/amp etc... you using with the ATC's? I did have my eyes (ears?) on a pair but ended up getting some PMC OB1's to use with my Bryston BP26/4B-ST combo. Sounds great in a large room but my small room will require some acoustic treatment to get the best out of the PMC's.
Cheers
Ah: Just noticed you other post: My current set up is : Naim CD3.5 and Flatcap power supply......ATC CA2 ( the new one..nice!)........Bryston 4B SST......ATC SCM 40..
ted_b
« Reply #2 on: 21 Jan 2009, 12:51 pm »
I had active (powered) ATC ASL SCM 150's and loved them!!  They were bought used, sight unseen pretty much, and when they arrived they overpowered the room somewhat, mostly physically.  I didn't keep them long, but they sounded great.  A more accurate speaker would be hard to find.  Good choice.
Mattyboy
« Reply #3 on: 22 Jan 2009, 05:45 pm »
Thanks Ted... I'm thoroughly enjoying them  :D!
So far it seems there isn't any body else using these great speakers with or without the gift of Bryston...:roll:
