Best Discs for CD R
0 Members and 1 Guest are viewing this topic. Read 3663 times.
carusoracer
Best Discs for CD R
« on: 20 Jan 2009, 04:57 pm »
I'm sure it has been covered before?
What are the best discs for CD R  Audio recordings?
mfsoa
Re: Best Discs for CD R
« Reply #1 on: 20 Jan 2009, 05:29 pm »
Best I've used are the MAM-A Gold. Archival quality (so they say) but at around a buck per they are pretty pricey.
-Mike
ted_b
« Reply #2 on: 20 Jan 2009, 05:40 pm »
-Mike
+1
They are expensive but sound great on your best burns.
http://www.mediasupply.com/mam11498-50.html
The Taiyo Yuden 80 min water shield are great everyday printable cd-r's too
http://www.mediasupply.com/tyd80wsh-50.html
marklivia
« Reply #3 on: 20 Jan 2009, 07:40 pm »
+2. Great discs.
bprice2
« Reply #4 on: 20 Jan 2009, 08:41 pm »
I've been using the black Memorex CD-Rs.  Where do these rank in the scheme of things?
Also, where do the +1s and +2s come from?  I've never seen that before, but I'm also a cultural illiterate.
BradJudy
« Reply #5 on: 20 Jan 2009, 08:46 pm »
The +1/2/3...  is a show of support for a statement, a web forum way of saying "what he said".
A little bit of trivia - the "black" CDs are actually a very dark red.  You can hold them up to a light and see red shine through.
ted_b
« Reply #6 on: 20 Jan 2009, 08:48 pm »
I used to like the black Memorex but found too many drives that spit them up, for whatever reason.
The "+1"s and so on are like "I second the comment" or "me too".
bprice2
« Reply #7 on: 20 Jan 2009, 08:59 pm »
I see.  I've just never seen the +s before.  Regarding the trivia about the "black" CDs, you are correct.  I never would have imagined until I just took a look for myself.
marklivia
« Reply #8 on: 20 Jan 2009, 10:21 pm »
It is said the "black" cd-r's don't last that long. The Gold MA 's are good for 200 years.
carusoracer
« Reply #9 on: 20 Jan 2009, 10:52 pm »
Thanks for the replies!
I have will look into the Taiyo Uden discs.  I have used Taiyo  Uden before and this new disc looks promising. The MAM look great but I do not believe that me burner is of high quality yet.
I have not had great longevity w/Memorex Black,degradation of sound after time and easily scratched. But that was over 4 years ago.
Ted B, what's your setup when you go for your best burns?
ted_b
« Reply #10 on: 20 Jan 2009, 11:10 pm »
I use Nero and my run on the mill DVD-R/cd burner in my Dell tower (TSST TS-H653B).
low.pfile
« Reply #11 on: 15 Feb 2009, 07:48 pm »
another question
I need CD-R blanks for some archiving.  I was ready to buy the MAM-A/Mitsui 1-12x Gold Audio Master Discs recommended but they are only 650MB. I do have some CDs that are over 650MB.
  So, is there another brand that is almost as good as MAM-A, but 700MB?
Hmm......I just did a random check on CD sizes in my library and see that Madredeus, Antologia CD is 785.6MB.
Thanks, Ed
birdwizard
« Reply #12 on: 15 Feb 2009, 09:43 pm »
I dont get it. I thought this was the discLESS circle :duh:
Taiyo Uden.
bprice2
« Reply #13 on: 15 Feb 2009, 11:37 pm »
Taiyo Uden.
Yes, it is.  And most of us here are working towards having LESS discs.  aa
Russell Dawkins
« Reply #14 on: 16 Feb 2009, 01:29 am »
I use Taiyo Yuden. Most archival grade discs play with more errors than these but are supposed to last much longer - they say 300 years - so I use Taiyo Yudens for masters and burn a Verbatim Ultralife Gold Archival grade which uses gold and silver for reflectivity for archival purposes.
Here one of a few sites where this is gone into in depth:
http://club.cdfreaks.com/f96/
