0 Members and 1 Guest are viewing this topic. Read 3191 times.
7. DSD is better. Having listened to reproduction from unadulterated DSD 2 channel masters for five days, in A/B comparison with the unimpeachable live music source, I'll say without reservation that DSD is capable of completely natural and faithful music reproduction. It's difficult to edit, mix, and EQ DSD, but still, technology for near perfect music playback is here, now. A single stereo mic feeding a DSD recorder gives great sound once you move your musicians around to balance out their sound.Your comments on the above are welcome.
What does DSD stand for??? Thanks,John
Dipole Bass, how is it done with two VSS subs? Right now I took off the bases tuned one on it's side with the cloth facing the front. The second sub I also tipped on end and turned upside down on top of the first sub. Both cloth sides facing out and one bottom woofer facing left and the other facing right. I still have them wired right channel, left channel in phase.Did any of the press write up your system?
Sounds like a success - I hope there is some good press coverage. In my limited perspective it seems that VMPS is one of the few that puts an emphasis on reproducing an accurate representation of the live experience and it seem that it takes a good sized speaker or speakers to do this. I was intrigued with using 4 subwoofers for what was basically a small acoustic combo. Good job.I am interested in the dipole subs will we see a new VMPS dipole sub? I have the RM30-M's and two original subs and the article has renewed my experimenting with the interaction between the 30M's side woofer and the subs. It seems there are a lot of timing, phase and directionality issues with multiple subs especially in a large room.Keep up the good work.Tom Brooke
