Behringer EQ for open Baffles?
0 Members and 1 Guest are viewing this topic. Read 2491 times.
Zero One
« on: 19 Jan 2009, 10:34 am »
I am currently finishing the build of my open baffle system and looking to set up appropriate equalization and are examining all the options.  I have noticed that behringer have a 31 band equalizer that can be purchased very cheaply new (about $180.00 Au) and looks as though it could be OK.  In the end it would be cheaper than my building my own Equalizer ( I was going to (build a three band parametric) and probably far more flexible, but has anyone used this beasty and if they have was it any good?
Thanks in advance
Zero One
dewar
Re: Behringer EQ for open Baffles?
« Reply #1 on: 19 Jan 2009, 11:32 pm »
Which Behringer, the BFD Feedback Destroyer I'm guessing at that price? Used it happily on my subs but it was not too good when I tried it out of interest on my mains. I've used the DEQ2496, which is about Au$400, on my mains and its quite good if you feed it a digital signal, and very good if you feed digital out to a good external dac. I use the DEQ only on my subs now, and its probably a bit of an overkill, but I'm also using the 12db low-pass feature which is quite useful.
cheers
B
Zero One
« Reply #2 on: 20 Jan 2009, 01:54 am »
Hi Dewar
It is the FBQ3102 ultragraph pro.
Cheers
Brad
dewar
« Reply #3 on: 20 Jan 2009, 10:17 am »
The BFD is the DSP1124P, see here  http://bfdguide.ws/
The DEQ2496 is the Ultracurve Pro.
Havnt heard of the FBQ3102, but it looks to operate in the analogue domain only so likely not too transparent. I see there is an ULTRAGRAPH DIGITAL DEQ1024 which seems to be its digital equivalent and likely a better bet, but I've not heard of this one either. Search audiocircle and google for opinions of people using it for hifi (as opposed to professionally). cheers
