Audio/Video Gear and Systems
The Discless Circle
toddbagwell
Easy playlist creator
0 Members and 1 Guest are viewing this topic. Read 1280 times.
Thump553
19 Jan 2009, 02:34 am »
This is probably a very basic question, but I never ever use playlists. My wife has asked me to make a couple. What software/method is the simplest way to do so (preferably freeware).
Nearly all my library is FLAC files, some mp3s.
jholtz
ยป
Re: Easy playlist creator
19 Jan 2009, 04:45 am »
I use Winamp Playlist Creator which is free and very easy to use. Here is a link to a download website.
http://www.softpedia.com/get/Multimedia/Audio/Other-AUDIO-Tools/Winamp-Playlist-Creator.shtml
HTH
Jim
Thump553
Reply #2 on:
22 Jan 2009, 06:19 pm »
Thanks for the link Jim, that program worked perfectly.
BTW, before using that I tried to save playlists under foobar and use them under slimserver but it just didn't work for some reason.
The Discless Circle
toddbagwell
