Woofer Connectors
0 Members and 1 Guest are viewing this topic. Read 1194 times.
Zene
Woofer Connectors
« on: 18 Jan 2009, 11:48 pm »
Hi ... I have the push type wire terminals on my P.Audio (P150/2226) woofers. There is no room to get between them and the cone so I cannot replace them with standard binding posts where I would use spades. What is best choice for the wire ends? I see four: plain wire (using multi strands of Cat 5), soldered bundle, pin type or soldered section with loose wires pigtailed so there might be more contact area in the terminal. Appreciate your help. Zene
Zene
Re: Woofer Connectors
« Reply #1 on: 25 Jan 2009, 12:06 pm »
Thanks! I wanted to try here first, as I thought the expertise/help was good. Now, I'll get some responses.  Zene
JoshK
« Reply #2 on: 25 Jan 2009, 04:07 pm »
I'd solder the end of cat together.  For ease as much as anything else.  There is no wrong answer, just convenience.
Zene
« Reply #3 on: 26 Jan 2009, 01:13 am »
Thanks Josh, I may have been over thinking it.  Zene
