Need help with Scott 299 tube integrated amp
0 Members and 1 Guest are viewing this topic. Read 2974 times.
thunderbrick
  • I'm just not right!
« on: 18 Jan 2009, 06:47 pm »
Just like many of us I am an audio packrat.  In a similar vein I am hauling stuff out of the basement and deciding what stays and what goes, and here is today's puzzle.
I have a Scott 299 (299c, I think) tube integrated with the original metal cabinet, and as far as I know the original tubes.  It powers up, tubes light up, and it does everything it should, but no sound comes out.  I am fairly adept at trouble shooting, checking all the switches, etc. and have gotten nowhere.
Any suggestions would be welcome, but when all is said and done I want to sell it, and I want to be totally confident in how I list it.  If I can fix it easily, it would better for all.
Bob
Atlplasma
  • Just off the boat
Re: Need help with Scott 299 tube integrated amp
« Reply #1 on: 18 Jan 2009, 11:04 pm »
You might also consider checking out the www.AudioKarma.org website. You'll find several Scott enthusiasts, and one of them might be able to help you troubleshoot your amp.
Niteshade
    • Niteshade Audio
« Reply #2 on: 18 Jan 2009, 11:15 pm »
Check the high voltage supply. I assume there are no missing tubes, right?
