Scott Nixon Tube Dac+ w/ 3ax PS
0 Members and 1 Guest are viewing this topic. Read 3623 times.
Christof
« on: 17 Jan 2009, 05:45 pm »
I just installed a Nixon Tube Dac+ in my system and would like to post a few comments for those interested in Nixon's products.  To preface, I have been listening mostly to vinyl lately and I've been veering away from PC audio.  My iMac G5->Firestone USB Dac sounds quite nice but there is a bit of a (digital) edge that gets to me during extended listening.  My room is big, live and for the most part untreated.  In this room I prefer a warm full sound which I get from vinyl and listen near field.  My vinyl rig is relatively nice, nothing to write home about but serves it's purpose, it consists of Project Perspective TT w/ Grado Plat Ref cart-> Monolithic PS1-> Odyssey Candela->SS amps.....Selah 3-ways.
I recently picked up a new Oppo 980H and a used Scott Nixon TubeDac+ & 3ax power supply for kicks.   The Nixon comes stock in a little plastic box which moved all about under the weight of my Zu Ash cable.  I think the cable weighs more than the DAC.  I decided to rebuild the DAC into a much more solid wooden enclosure and upgrade the signal path with Ridge Street's solid silver hook-up wire.  I also switched out the IEC socket while I had the DAC apart.  Unfortunately I did not have much more than a few minutes listening time on the DAC before I rebuilt the case and added the new wire so I am not able to give a direct comparison of the stock vs. slightly upgraded versions.
As for the sound I am very impressed with the Nixon DAC.  Playing the same reference passage ("Zigeunerweisen" Uncommon Ritual/Sony Classic) on the Oppo without DAC, iMac & Oppo with DAC provided quite a difference to my ear.  The digital edge or harshness which annoyed me previously is gone with the Nixon DAC, imaging improves slightly by becoming a bit more 3D and midrange/bass become slightly more prominent which is perhaps due to the smoothing of the highs.  The Nixon DAC gives me a more relaxed, analog sound that I can listen to for extended periods without the "digital fatigue".  As a side note, I hear no difference when the X-sinc filter is turned on or off and cannot comment on the effect of the Ridge Street wire upgrade.  I truly encourage anyone who is interested in an inexpensive NOS dac to give this little guy a shot.
cg.
Edit:  I am using an Adzam SQ E88CC tube
