Off Ramp Turbo 2 format question
0 Members and 1 Guest are viewing this topic. Read 1610 times.
ClarKit
« on: 17 Jan 2009, 02:01 pm »
Hello
I have Vista on my laptop with output to Off Ramp T2, if I check "Control Panel" "Sounds" etc it shows that the following formats can be output to Off Ramp 24/44.1  24,88  &  24/96. So under Vista I cannot send 16/44.1 to the Off Ramp.
On this site it states "will pass most audio formats, including MP3, .wav @16/44.1, .wav@24/88.2, .wav @ 24/96" suggesting that the Off R passes 16/44.1 untouched.   In reality is it that if I could send 16/44.1 Off Ramp would convert it to 24/44.1 ?
In other words are the 24/44.1 24/88 & 24/96 formats shown under Vista the only outputs of the Off Ramp (i.e. Off Ramp would convert a 16 bit input to 24 bit).
All the best
P
audioengr
Re: Off Ramp Turbo 2 format question
« Reply #1 on: 17 Jan 2009, 08:28 pm »
Hello
The data is not modified when it converts 16 bit to 24 bit.  This is generally an improvement and causes Vista to output bit-perfect 44.1, which Vista will not do with 16/44.1 unless you use Kernel Streaming.
In other words are the 24/44.1 24/88 & 24/96 formats shown under Vista the only outputs of the Off Ramp (i.e. Off Ramp would convert a 16 bit input to 24 bit)?
That is correct.  These are the selections.
24-bit has the secondary advantage that you get 8 bits (256 steps) of volume control without impacting the data bits. This is why Sonos also generates 24/44.1 from 16/44.1.  It's beneficial.
Steve N.
ClarKit
« Reply #2 on: 20 Jan 2009, 09:19 am »
Steve - I understand that usb2 drivers generally are restricted to 16bit so do your drivers allow 24bit input to off ramp ?
all the best
P
audioengr
« Reply #3 on: 20 Jan 2009, 06:49 pm »
all the best
P
Yes, the Off-Ramp does 24-bit up to 96kHz sample-rate.  It uses the native OS drivers.  No driver to load, no ASIO to install.
Steve N.
